Thread: creaking front end
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default creaking front end
    i have recently noticed creaking comming from the front of my car when turning into my drive any ideas , I have changed strut top bearings, springs and spring sleeves but the noise seems to be further forward i also sprayed wd 40 around all the bushings
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Radiator mounts...try a search for the numerous threads on it. Usually fixed by WD40.
    Nottinghamshire
    The 2 anti-roll bar bushes can creak. You can see them if you look down behind the engine - there's one on each side on the top of the subframe.
    There are how2's on here about replacing them. As a temporary fix, I sprayed mine with a little silicone lubricant and that has quietened them down for now.
    Jul 2009
    The Rift, Cardiff
    I had a nasty knocking noise frm the front, both springs were snapped. Had them replaced but still a quite a bit of noise. It was the anti-roll bar end link rods.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks for the replys peeps i will have to get out the white sprsy grease
    Apr 2009
    liverpool
    My 2.2DTI SRI creaks on speed bumps, funnily enough mainly at the start of a journey, I'm pretty sure it's the anti-roll bar bushes.....I'll try the spray silicone, thanks
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    usually its the radiator mounts when we have damp conditions, could well be anti roll bar bushes, aswell as drop links or track rod ends.
    Sep 2009
    northumberland
    would guess at radiator mounts think they around £13.50 each ic vat part no 13186475
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    HI mine does this only in the winter months and when very wet.
    Plymouth
    If it does it over bumps when both wheels go over its the anti roll bar bushes..
    Under £15 for parts over £120 for labour!!!
  1. creaking front end
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2012, 11:15
  2. creaking from the front
    Last Post: 11th October 2009, 19:24
  3. creaking from front end
    By tony whin in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 21:53
  4. Creaking from front
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 8th December 2008, 22:16
  5. Creaking from front - 03 1.8 SXI
    By addyboy1982 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2007, 21:14
