Thread: 3.2 v6 problem
    WALES ENGLAND
    Default 3.2 v6 problem
    Dash light on the one with a car and a spanner going through it, only came on since i put new air filter in help!
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Check the MAF sensor plug is back on properly, (assuming you took it off to change air filter).
    WALES ENGLAND
    Quote Originally Posted by bigcarman79 View Post
    checked that even put old filter back in just incase new one was bust
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Try disconnecting the -ve side of the battery for an hour or so. The spanner light might clear itself.
    Had this on mine when changing the air filter but in my defence, I had forgotten to plug the MAF back in.
    Does the spanner light just come on briefly when you start up and then go off? If "yes", then not much to worry about. If it's on all the time, then it's a bigger problem which I haven't got an answer for.
    WALES ENGLAND
    just took it on motorway and it flys as normal 1st 2nd 3rd 4th and 5th no problems.
    WALES ENGLAND
    rolleyes
    Quote Originally Posted by gtr1000 View Post
    yer goes off soon as start up .
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by DECO View Post
    Mine's been on and off for the past 18 months but is for a different reason - incoming air temperature. Like yours, car's performance is 100% and can't fault anything so I live with it.
    Try this http://www.vectra-c.com/forum/showthread.php?t=81742 and come back to us with the results. HTH
    Full Member Big Sig's Avatar
    yes it goes off as soon as I start it up .
    That means its an old fault code, not an active one iirc
    Jan 2008
    Pontefract
    Yes that is correct. Mine has started to illuminate and go out again when started.....happened when i had wheel spin in reverse, dunno why but it upset something briefly (Auto)!!!
    This symbol should disapear after ( i think) 20 to 40 fault free starts
    WALES ENGLAND
    I think ill leave it for now,car runing great so stuff it ill just keep an eye on it. In facted since i changed air filter oil filter and oil and put injecter cleaner in it its run better now than it was so stuff knows ??????????????????????. thanks every one.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
