Results 1 to 10 of 23
Thread: 3.0 cdti additional water pump location
    Riga, Latvia
    Default 3.0 cdti additional water pump location
    anyone knows where is located the additional water pump on the Y30dt engine?
    Full Member Big Sig's Avatar
    Additional? do you mean the coolant water pump?
    Riga, Latvia
    no, i mean auxiliary or secondary coolant water pump, part no. 13 34 141
    main coolant water pump part. number is 13 34 144, and i know where it is.
    at this link part "29" http://www.webparts.ru/opel.lmz?p=1&...008620#anct_23
    p.s. sorry about my english spelling
    Regular Member Eirik's Avatar
    Aug 2009
    NORWAY/Kristiansand
    I think you can spot it from underneath, if you loosen the bottom engine plastic cover(have noe idea what its called in english). But it is the little corner cover on the left, that you have to fold down to acsess the fog/cornerlight bulb. Then if you just take a look up there betwen the radiator and the engine you maybye spot it...
    Riga, Latvia
    Quote Originally Posted by Eirik View Post
    I think you can spot it from underneath, if you loosen the bottom engine plastic cover(have noe idea what its called in english). But it is the little corner cover on the left, that you have to fold down to acsess the forlight bulb. Then if you just take a look up there betwen the radiator and the engine you maybye sport it...
    thank you!
    I had no idea it had 2 pumps!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    same here sig it's a new one to me !
    whats the second one for??
    Aug 2009
    NORWAY/Kristiansand
    Better flow/circulation i think, have it on my Omega 3000/Carlton GSi(30ne) and had it on my Omega MV6/Elite(x30xe). But they were coupled inn to the heater system, standard in norway. But the MV6 had one extra that activated when it was hot and the cooling fans started, this pump circulated the water around in the radiator, it was also active when the cooling fans cooled down the engine when i stopped it.
    Wonder if we have them on the uk spec cars?
  1. £280 for Cam Belt and Water Pump Change on a CDTI 150??
    By Henry42 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2013, 20:51
  2. CDTI water pump?
    By bigdave1701 in forum Engine & Drivetrain
    Last Post: 4th April 2012, 15:34
  3. water pump cdti 150
    By dave r in forum Diesel Engine related
    Last Post: 2nd June 2011, 22:14
3.0 cdti water pump location
signum 3.0 v6 water pump
3.0 v6 cdti vectra water pump
vauxhall signum v6 water pump
vectra v6 cdti water pump
vectra v6 cdti water pump location
vauxhall 3.0 v6 diesel engine using water
vectra c auxiliary radiator pump
vectra 3.0 v6 cdti water pump
opel 3.0cdti water pump location
