Thread: Help re Oxygen sensor for Z32 SE V6
    Regular Member the-converter's Avatar
    Australia
    Question Help re Oxygen sensor for Z32 SE V6
    Does anyone know how many oxygen sensors in a 3.2 V6 engine?
    My mechanic did a scan on my car and he found out one of the sensor is not working.
    I was thinking to replace the whole set myself but I need to know how many sensors I need to buy.
    Does the front and rear sensors are the same?
    Does anyone know the part number?
    How difficult is this job?
    Anyone have replaced o2 sensor before?
    I think there are 3 sensors in total. Its not too bad as long as they come out ok as they will be very tight!
    Regular Member gsi.vxr's Avatar
    Hertfordshire
    I though there was 2. Correct me if I'm wrong.
    Melbourne, Australia
    There are four in total. For each cylinder bank there is one before and one after the catalytic converter.
    The mechanic should be able to identify which sensor is not working by the scan tool. You shouldn't need to replace all of them
    Hertfordshire
    Quote Originally Posted by stevedee3 View Post
    Yes, your right. All use the same part number too apparently. Can't help with the number though.
    I forgot to mention: you should be able to read the fault code(s) yourself using the procedure documented in this thread.
    Quote Originally Posted by gsi.vxr View Post
    We were fairly close!
  1. Oxygen sensor removal
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 15:54
  2. Lambda / Oxygen Sensor
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2012, 21:13
  3. oxygen sensor
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 23:25
  4. Oxygen sensor!!!!
    By darrenmac in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 16:53
  5. oxygen sensor
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th June 2008, 20:43
