Thread: Can i get a CID decoded?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Can i get a CID decoded?
    Does anyone know if I get a CID that hasnt been tech 2d can i get it decoded? If so where and how much?
    Also do all CID's work with with half canbus cars?
    Thank you in advance
    Stephen
    Regular Member adfrodsham's Avatar
    lincoln
    i removed my cid without tech 2 and worked in another car, also yes will work with half canbus
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Not All CID is a straghit fit in all the vectra/signums..
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by adfrodsham View Post
    Bet you had the HU as well
    I know some one that can reprogram CID's but first of all he would need a dump of the firmware from one that's been de-paired then he flashes the coded one to make it de-paired
    Irmscher Insignia CDTI 130
    Regular Member darko2301's Avatar
    Croatia
    Quote Originally Posted by bigmac View Post
    well it doesnt have to be.. if you still remember mate i borrowed a cid from my friend a few months ago to test if it would work in my car and it really did, it wasnt locked but the only problem was that i couldnt control it because you need a ncdc series radio for that, wiper stalk wont do the job..
    as far as i remember it wasnt decoded because it came off a scrap yard..
    so zigmond,
    you'll also need to invest in a ncdcxxxx series radio or you will have no use of your cid unfortunately..
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    I can provide your CID code if the display arrives to me or find a good electronic workshop to read the internal eeprom and send the content to me.
    When you have the right code it possible to program/set/reset your CID in your car with Tech2.
    CristianTM.
    Devon
    70 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by darko2301 View Post
    so zigmond,
    I had the same experience mate with a CD70 cid i put that in my car and it worked but didn't have radio control,but your right you will need a corresponding HU but once its connected it will see its not the same code and then it wont communicate and display safe
  1. decoded ecu.
    By gibdratsab in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2012, 22:13
