wot resister do i need to stop error codes anyone know thanks
And the vague question of the week award goes to.....
Error codes for what?
Airbag?
Sidelights?
Headlights?
AN Other?
You cant stop error codes, they are there for a reason. You'll probably damage your car trying to put resistors in place where your not supposed to.
sorry for side lights
Measure the resistance of a lamp - then get a resistor
should it be the loading on it as well? if you use a 1/4watt 25ohm resistor and the lamp for example pulls 2 watts.. boom goes the resistor
Depends if its in parallel or series I guess??
would be in parallel to simulate the current draw. then you have to take into account the resistance of the led's being fitted too
