Thread: Lacquer on Alloys?
    Regular Member @ndy-e's Avatar
    Warrington
    Question Lacquer on Alloys?
    Nothing too technical but basically bought some second hand alloys on ebay and on closer inspections now i have them it does seem they have been painted. That said they still look good but in places the finish is rough to touch, so my question is how do i lacquer it to give a sooth finish bearing in mind never done anythin like that before?
    WGAF#5
    you need some wet dry and rub back the finish till its nice and smooth - be careful though as begin too exuberant on the old elbow grease will render them requiring a respray as well
    dependant on the "feel of them i would recommend a finer grade wet dry to start then you wont risk taking off too much finish if you havent used it before
    then give them a very good clean - make sure there is no grease or dirt and mask off the tyres and anything you dont want to spray
    use a well ventilated area - and give as many thin coats as you can leaving roughly half an hour to an hour to dry now the weather is getting cooler- the more layers the harder the finish will be - and then leave to harden before refitting then give them a coat of polish and a paint sealant to protect the new finish
    hth
    regards
    Dez
    WGAF#5
    leaving roughly half an hour to an hour to dry now the weather is getting cooler (between coats that is )
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    You could also just try some clay as it might be just overspray or just contamenants stuck to the wheel. Its easier than repainting and it might do the trick
    Warrington
    Cheers mate. I take it I rub them dry? lol
    Warrington
    Good idea Andy will try that first as i did try a little polish to see if anythin come off, which in places it did!
  1. Lacquer has cracked on my alloys
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 12th April 2012, 21:35
  2. lacquer like substance in egr
    By taxidriver50005 in forum Engine & Drivetrain
    Last Post: 6th February 2012, 09:15
  3. lacquer peal
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 22nd July 2011, 15:13
  4. whats the best lacquer??
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 21:44
  5. Flakey lacquer
    By si_hoss in forum Detailing and Car Care Discussion
    Last Post: 31st August 2010, 16:15
how do i get a rough finish out of laquered alloys
