Thread: Help!! Clutch advice needed!!!
    May 2007
    GLASGOW
    Default Help!! Clutch advice needed!!!
    Hi was out last nite in my 56 plate cdti 150 and i have been having problems with the clutch sticking, but last nite when pulling away went to change gear and the clutch pedal sunk right back in to the floor and isnt rising to the top at all. Has anyone else had this and does this mean i need a new clutch or could it just be a cable or something? the car has 100,000 on it.
    also if anyone can recommend somewhere decent in the glasgow area preferebly eastend that would be great
    WGAF#5
    could be the slave or master cylinder causing the problems
    can you lift the pedal back up manually ?
    May 2007
    GLASGOW
    yes lifted the pedal back up when i pressed it back in it just stuck in again to the floor. the car is now un driveable
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    have you checked if you are losing fluid,as D say's it sound's like master/slave cylinder .also it could be gearbox input shaft that needs greasing on spline.
    May 2007
    GLASGOW
    ok excuse my ignorance but how do i check the fluid? im not too mechanically minded, and if it is the slave cylinder, any idea how much it should cost to fix it...thanks
    Jul 2009
    Engine : 20 Dti
    no idea on cost ,under bonnet to the left on bulkhead there are two fluid resorvoir's (plastic containers about the size of a cup)one is for brakes the other the clutch,there is a level mark on side of container ,
    May 2007
    GLASGOW
    thanks, will check in the morning!!
  1. Oil Leak+Clutch+DMF - Advice Needed Please
    By bigade1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 20:54
  2. Replies: 26
    Last Post: 1st March 2012, 20:49
  3. Clutch Advice Please....
    By spoons in forum Engine & Drivetrain
    Last Post: 13th October 2011, 21:16
  4. Car is going in to see if another clutch needed - What do you think?
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 19:04
  5. Rattle...advice...clutch?
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 27th February 2010, 22:41
