Thread: Mtec Hid bulb keeps going out
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Default Mtec Hid bulb keeps going out
    I have fitted an mtec kit a while ago and one of the bulbs keeps going out. this seems to happen more in damp or cold weather.
    I just turn the lights off then on again the the problem is solved but its starting to happen more often now and is beginning to annoy me.
    I have tried moving the ballast to a different place and coating it and wd40. but it still happens.
    Is this common? or is it about time to buy a new set?
    keith
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Lol funny you should mention that, I have exactly the same car, exactly the same colour and exactly the same problem.
    I'm thinking of buying a new kit though as mine has been on a couple of cars now and i want to get one with smaller ballasts
    11 Post(s)
    Swap the two bulbs over to see if one of the ballast packs is faulty.
    Sep 2009
    its nothing strange, it happens if you have weak battry aswell.
    try it, switch on the lights then fire up the engine, you'll see the lights go out. then you bulb warng light will come on the ballaster will go on safty cut out, untill you switch the lights off and put them back on.
    the lights shouldnt go out at all if you have good strong battary.
    ive done and tested this. it used to happen with my saab all the time changed the battary and all was good after that.
    Jan 2008
    Dundee
    thanks, i'll try that
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    I found that if you leave the car a few minutes after starting before switching them on helps
    Jan 2008
    Dundee
    yeah i have noticed that too. strating to **** me off tho. thinking about getting a new kit
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    i had a similar problem with my hids had to get resistor type things (a wee box to plug inbetween the bulb plug and balast)from america because my balasts where not canbus compatible mabe thats ure problem
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Thats not my problem mate
    I have the black boxes to stop flickering/bulb failure
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    **** knows then lol if there cheap ones probs goosed.
  1. Sidelight Bulb Comparison - MTEC 501 v Philips Blue Vision
    By puppet in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2013, 06:22
  2. HID's Direct 'MTEC' bulb life?
    Last Post: 6th November 2010, 22:20
  3. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  4. Another mtec bulb thread
    By Ian T in forum Styling
    Last Post: 12th February 2009, 20:46
