Thread: Tyre pressures on 215 50 17
    MIDS
    Default Tyre pressures on 215 50 17
    is 35 all round on 215 50 17 ok?
    i got lpg gas tank so extra weight
    i got goodyear nct ego tyres on there whats the best optimal psi cause am geting rubbish mpg??
    6 Post(s)
    The handbook recommends 32 (up to 3 passengers)
    33 f, 41 r with full load.
    What mpg you getting then?
    With LPG you'll get less mpg than when using petrol.
    Remember the LPG tank is at the rear of the car, so you don't need to significantly increase the front tyre pressures for it.
    Sep 2009
    Glasgow
    sure i seen some where 35 at front 36 at back.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Depends on engine size, wheel size and loading. I have a 2.0T and according to the manual it requires 35psi all round. My previous 'C' 1.8 was 32 psi all round.
    Quote Originally Posted by hinesh12 View Post
    Tyre pressure depends on body, engine and model
    Assuming your car is 1.8 saloon / hatch with LPG :
    Up to 3 passengers -
    Front 29
    Rear 32
    Full load -
    Front 29
    Rear 39
    If it is a different body and/or engine let me know
    Details are in your handbook at the rear
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
215 50 17 tyre pressure
tyre pressure 215 50r 17
vectra c 1.9 cdti 2155017 tyre pressure
21550w17 tyre pressure
