Results 1 to 10 of 11
Thread: let there be light?
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Question let there be light?
    just a quicky... ever since i've had the car the light doesn't come on when you open the door,..
    Having pressed the various buttons, all the lights seem to work on their own (as far as i can tell) is this just a bulb, common problem,.. how does the unit undo in order to inspect/replace bulbs? sorry feel a bit clueless about such a teeny problem, but it is annoying
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The large clear cover is just clipped in mate, slide a plastic wedge down the side of it and it will come off.
    Mileage : 000
    Could it be the door module that is not sensing that the door is open?.
    Do you have rear courtesy lights. Do they come on when the door is opened. Is it affected whether it is the front or rear door that is opened.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Do the lights come on when you unlock the car?
    Aug 2009
    Frinton on sea
    ooh will c have to check, lights near the number plate comr on when i unlock the car,... will have to check the rear doors, definately both front doors... thanks for the responses
    Aug 2009
    Frinton on sea
    Have opened each door in turn, no courtesy light either front or rear although rear ones come on when front light is turned on
    If it's the sensor,..is that a big (expensive) job?
    11 Post(s)
    Does the door open light (or door symbol, depending on age of car) illuminate in the speedo housing when a door is opened?
    Aug 2009
    Frinton on sea
    No, but the ding ding ding etc goes off when door is open and lights on or key in ignition,,,
    Aug 2009
    Frinton on sea
    i know it's not a show stopper or anything but not sure where to start to try and fix it.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does the light work if you switch it on manually?
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
