Results 1 to 10 of 13
Thread: Help! Front tyres, inside wear!
    Plymouth
    Unhappy Help! Front tyres, inside wear!
    Hi there
    Forgive me this is my first post and im new to this
    I have i vectra 52 2.2 sxi and had the front tyres replaced in feb this year and noticed that that they were both very worn on the inside, so i had the tracking done at the same time.
    Just had a recent service and noticed they are wearing on the inside again
    Does anyone have any ideas of why this might be happening or any ideas on how to fix it!
    Any help would be usefull, Cheers
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    have you been lowering the car?
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    is pressures ok ? check for wear insteering rack tie arms when you had tracking done was it a four wheel alignment machine or just floor guages
    Quote Originally Posted by paul wingnut View Post
    Typiclaly incorrect tyre pressures will not cause this type of wear; either
    both outside edges or middle of tread
    Inside edge wear can be caused by a number of factors including :
    incorrect toe, camber, and/or castor
    suspension chatter
    variable power steering, typically from roundabouts
    Most likely is incorrect camber from the rear as it is both tyres
    Sadly it is a cumulative effect, most likely caused from late swapping of the rears to the fronts
    Alternatively the toe on the front is incorrect, and as above is cumulative if the rear camber is also incorrect, accelerating the wear in the same place
    First course of action is new tyres replacing the worn fronts, fitted to the rear, swapping the rears to the front and a four wheel alignment check and adjustment
    If an adjustment is required, then another MUST be carried out again at 1000 miles, and further one when the front tyres wear out
    However, providing the tyres are down to the legal minimum evenly across the centre of the tread then there is nothing to worry about
    I
    've just had my front tyres replaced today, the nearside tyre was also clearly worn on the indside edge, but the tracking was found to be correct and no adjustment was required
    At the last change the nearside tyre had worn on the outside edge, so my car is suffering from "variable power steering, from roundabouts"
    This is typical if you live somewhere with a lot of roundabouts (especially a new town like Milton Keynes, East Kilbride, Cumbernauld, Glenrothes, etc)
    Regular Member Readster's Avatar
    Plymouth
    Quote Originally Posted by Wiggles86 View Post
    Hi there
    Another Plymouth member..excellent.
    Are you going to watch the supergreens tomorrow?
    Tyres, depends on several factors. Do you drive hard? Which tyres do you have?
    There will be a reason for your wear, Could be misalignment, wear or damage.
    Have you had the Vec long? Do you know its history?
    John
    Plymouth
    hell everyone
    thanks for the replies will try and give more info now for you all
    the car was four wheel aligned when it was done but it has been lowered since (30mm)
    the tyre pressures are done every other week and i dont drive it hard.
    Plymouth
    good to see another Janner
    Plymouth
    hell everyone
    Maybe the lowering has thrown the front camber out then
    Where do you go to get it checked?
    I can recommend Ridgeway Tyres in Plympton and Stadium Garage by the Cherry Tree pub.
    John
    Plymouth
    Quote Originally Posted by Diet1985 View Post
    You going tomorrow Diet?
    I'm taking my lad and its a freebie
    Plymouth
    Quote Originally Posted by Readster View Post
    going where?
  1. what would cause inside tyre wear?
    By krazylegz in forum Suspension, Wheels & Brakes
    Last Post: 6th June 2012, 05:55
  2. what would cause inside tyre wear?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 23:10
  3. Tyre wear in rear inside edges
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2011, 14:38
  4. wear in inside edge of rear tyres
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 23:45
  5. Switching tyres front to rear as they wear
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 18:31
