Results 1 to 10 of 11
Thread: High Beam Problem
    Jun 2009
    Bristol
    Angry High Beam Problem
    hi guys,
    i just had the high beam warning show on the dash, so i checked it and sure enuff the passenger side high beam was not working.
    So i swapped the bulb and its still not working !!
    all other lights are fine..
    confused to say the least, any ideas ??
    thanks
    matt
    Full Member Big Sig's Avatar
    Have you checked the fuse?
    Jun 2009
    Bristol
    are they seperate ? the drivers side high beam is fine.
    Thanks for the reply by the way
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Try swapping the bulb with the one on the drivers side. You will be 100% that bulb is working.
    Jun 2009
    Bristol
    I have a spare set of bulbs tried both of them and it wont work, and I know both these bulbs are ok.
    does anyone know which fuse it is on a 55 plate facelift vectra c ??
    I am checking the manual but cant find the exact fuse
    Mileage : 000
    Acording to my "book" page 217 says it is fuse no8 front headlights. It seems that they are both on the same fuse?? it is a 10a fuse. it is the fuse box under the bonnet by the battery.
    Jun 2009
    Bristol
    just checked my book , it was page 241, it says fuse no 8: headlights, windscreen washing nozzles. its a 10 amp. i pulled the fuse but all the lights still work , so it cant be that fuse. fuse looks ok aswell.
    thanks for your help
    Do you have anyway of checking for voltage at the bulb holder?
    Regular Member Swaite53's Avatar
    South Wales
    Could be a bad earth. Clean the contacts of the plug before putting the bulb in.
    That number 8 fuse is for the washer pump, for the windscreen and the headlights, not the ehadlights themselves...
  1. high beam bulbs
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 18:31
  2. High beam bulbs?
    By shb1988 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2012, 18:05
  3. High beam" warning??????
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 01:33
  4. best bulbs for high beam
    By andy_hare in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2010, 18:27
  5. Signum High beam
    By TONYWING in forum Vectra C / Signum Troubleshooting
    Last Post: 9th November 2008, 15:25
hi beam dosnt work on my vectra
