Thread: Swirl Bar Actuator: Diagnosis Needed!
    Regular Member barkzz's Avatar
    Exclamation Swirl Bar Actuator: Diagnosis Needed!
    Hi All,
    My car has been chugging on startup giving off nice amounts of grey smoke in the morning. This has now also led to poorer fuel consumption.
    To my horror, i took the cover off today to have a nosy and it looks like the swirl bar item, is just sat there, not even covering the 4 holes. The 4th one is extremely gunked up.
    I've posted some pics (not great quality), and was hoping if you could confirm my diagnosis.
    The car was bought from Network Q, and is still in warranty till february so if it is terminal, I want to get it booked in ASAP.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Don't if that's the REAL cause for the gray smoke you're having, but if you have warranty until Feb., I'd change the manifold anyway.
    Quote Originally Posted by Lao View Post
    But do the pictures seem to prove my theory correct? That the swirl bar is goosed?
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Mine looked worse than yours, so...
    Full Member Big Sig's Avatar
    It looks still attached to me
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Looks fine if it was off it would be lying on its side and you wouls see the pegs that it connects to.
    Also if it is a couple of years of at least I'd says its had the manifold replaced.
    As for chugging EGR? Possible air leak?
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    you have the old design manifold and has not been changed by the look of it, look here to see the difference http://www.vectra-c.com/forum/showthread.php?t=92579
    i would point this wear out to your dealer also the underlying problems with smoke etc, beware as they may only clean the egr and may avoid any replacement of the inlet manifold before your warranty runs out. one of the MOST annoying things about this problem is that every time you come to a standstill with your heater on it drags fumes in from the engine bay that are leaking from the manifold.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    you have the old type of Inlet for sure..
    but it doesnt look to me like the bar is off.. The bar sits on pegs that have a ball type joint...
    If its still in warrenty *cough* pull the bar off *cough* :O
    Thanks guys, EGR and boost sensor have both been cleaned by myself, and according to the chassis number, it shouldnt be one suffering from the 3rd injector issue.
    Can't say ive notied it dragging in fumes when at a standstill, but there has been a definate downturn in acceleration under 2k, and also drinking more diesel.
    I'll take it into vx, where they will no doubt mention "if we cant find anything wrong, you will be charged £85 inspection fee"
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    did you clean the hole in the inlet manifold where the egr bolts on ???, its only a small hole and always gets blocked so when you clean the valve it still don't allow full flow ! its awkward to see and get to but its a must.
  1. Swirl actuator
    By carl78 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 11:44
  2. Swirl flap actuator
    By jofenan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 21:01
  3. Swirl pot actuator
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 21st November 2009, 01:00
  4. Swirl Actuator Bar - Advise please....
    By VX150-VECSRI in forum Engine & Drivetrain
    Last Post: 28th September 2009, 18:42
  5. Swirl Actuator Problem... or not?!
    By djr69uk in forum Engine & Drivetrain
    Last Post: 2nd May 2009, 21:18
