Thread: 3.2 thermostat location
    Full Member Big Sig's Avatar
    Default 3.2 thermostat location
    Can anyone point me in the right direction for the thermostat on the z32se engine please
    Mileage : 000
    Sean. It is buried somewhere very deep down inbetween the Two Vee Banks. I belive it is not a five minute job, as you have to dig very deep to find it. Unless you are good with spanners I would get a garage or a mechanic mate to do it for you.
    I have been told its an hours labour, I can see something with a bottom rad hose going to it above the gearbox, not sure if this is it?? Don't fancy the £160+vat they want to charge me!
    Mileage : 000
    Thanks Ed, I did a quick search and missed those....... think I may have a poke about then call the garage!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Hi Sean - would you believe, since we last spoke, my rear valve cover on the front bank of cyclinders is letting oil by .
    Thought I'd have a go myself but, after following the "How to" for a 3.2 plug change, gave up as I couldn't get the plenum chamber undone, let alone take it off. This you also need to do to get to the t.stat.
    My problem ssems to be that the plenum is held on my 6 bolts. Only one is visible and the other 5 need a a torx bit on an extension. Can't remember what size Torx (T30 I think) but when attached to a 3/8" extension drive, the extension is too big to go in the holes. I've got a 1/4" extension which is fine, but my T30 is only for a 3/8" drive.
    So I've given up and it's going to an indy garage next week. Have been quoted around £150 and that's to do all four gaskets as no doubt the others will give up at some time. VX wanted £328 + Vat and wanted to fit new valve covers as they claim the old ones can warp. (Bull S???)
    Labour times are akin to changing the plugs @ 0.9 hours so you may as well consider doing the plugs, thermostat and valve covers as well given the amount of work to remove the plenum.
    HTH
    Quote Originally Posted by gtr1000 View Post
    HTH
    See you have upset the car with talks of sales!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Yes, what a bumma
    And there goes the cash I was gonna spend on my motorbike suspension.
  1. Thermostat location - 2.2 Direct
    By Big Dave in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 12:59
  2. Z20NET Thermostat Location
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 21:58
  3. Thermostat location? Sloppy Stick!
    By stevensred5 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 15:28
  4. Thermostat location 2.0dti
    By bran.c in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:20
