Thread: Fuel flap central locking motor failed!
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Default Fuel flap central locking motor failed!
    Anyone had this problem?
    Went to fill up this morning and the flap was jammed. Went in through the side panel in the boot, and loosened the motor from it housing and opened the flap. Pushed the motor back into it's housing and tried the cenral locking with the flap open; it's locking, (rod from motor is sliding out), but not going retracting when unlocked.
    Hope it was just the cold weather last night!!!
    Cheers,
    Paul.
    Snowman, you got your ears on?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Cold weather, what cold weather?
    Full Member Big Sig's Avatar
    Maybe give it a spray of lube?
    Oct 2007
    Horley, Surrey
    Brass monkey's here in Surrey last night. Down to about 10° last night!!
    I doubt the lube will work as there's no sign of life from the motor at all when I unlock. Wonder if the Cavalier motor is the same as got a few in my toolbox!
    Will keep you posted.
    Paul.
    Oct 2007
    Horley, Surrey
    Well it looks like the motor is knackered.
    Took it out of it's housing behind the wheel arch and locked and unlocked the car loads of times. The motor ram comes out but not back in.
    Not desperate but will need a new motor. See if i can wangle it on warranty.
    Paul.
    Aug 2009
    n ireland
    i have the same problem so when to scrap yard and got another one and the same thing so it might not be the motor might be no power getting to the motor to pull the rod back in mush check mine as well, worth checking to save wasting money
  1. Locking Fuel flap
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 21:19
  2. Fuel Filler Flap Locking Motor
    By jimmy495 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th September 2011, 22:34
  3. Fuel Flap Locking Solenoid
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2011, 09:21
  4. central locking motor
    By madman in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2009, 17:38
vectra fuel flap opens with central locking
