Results 1 to 2 of 2
Thread: Signum rear dampers
    Regular Member bogbody's Avatar
    Jun 2007
    Peterborough
    Vehicle : Astra
    Engine : 1.6
    Default Signum rear dampers
    Well having spent a wad on front springs I've discovered today that one of the rear dampers on my 2002 Signum 2.2dti is leaking. A lot - it's dripping on the floor! Yes it is oil and not brake fluid - also checked by a mechanic mate.
    Doesn't look to be too bad a job, access to the top bolts might be awkward without a ramp or a pit. is my assumption right? The springs and dampers are separate on the Signum not a strut. What is the torque settings for the bolts holding the dampers?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Very common fault on all vectra,s and signum,s mate, fortunately also one of the easiest to rectify , just enter rear shock absorbers into the search category and you will find plenty of help there , the standard vx units are rubbish at best and usually only last around 30-35000 miles , replace them with bilsten units a much better damper .
  1. Dampers
    By stephen.taggart in forum General Chat
    Last Post: 31st December 2012, 09:07
  2. Torx Bolt Size - Rear Suspension Dampers
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2010, 16:51
  3. Should I transfer my dampers to my new car?
    By merikiito in forum Handling & Braking
    Last Post: 9th February 2008, 20:50
  4. Sri Springs on LS dampers
    By JCB in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2007, 13:26
