Results 1 to 10 of 15
Thread: 3.2 V6 Rocker Cover Gaskets
    Regular Member Bobarache's Avatar
    Perth, Australia
    Default 3.2 V6 Rocker Cover Gaskets
    Recently I have found some serious looking oil drips in my garage and went searching in the engine bay for the source.
    It appears that both front and rear rocker cover gaskets are weepng.
    Does anyone have any advice n what to be careful of when changing these gaskets ?
    Do I have to remove the inlet manifold and what is the best way to do this.
    I also hear a bit of a noisy bearing noise, what is the best way to try to isolate where it is coming from ? and can any one tell me where the belt tensioner is as there is so much room in there.....not !
    Haha so many questions.....
    Glasgow
    If your getting a noise around your belts aswell i would look at your oil pump gasket aswell. It went on mine and supposedly the dealer has done a few of them not a quick job either
    If it is that its also a good chance to get the timing belt kit done.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Find the "How to" on changing the spark plugs. Shows how to get the plenum chamber off and therefore access to the covers.
    I've tried on my 3.2 but have given up.
    Perth, Australia
    confused
    Quote Originally Posted by byebyeitsagsi View Post
    Where abouts is the oil pump located, is it at the rear ?
    Frustrating thing is I only had the timing belt and kit done about 7000kms ago and am concerned that it could be the tensioner.
    Will give the engine bay a good degrease and wash today and then explore some more.
    Perth, Australia
    Quote Originally Posted by gtr1000 View Post
    Cheers for that mate, if you have given up does that mean it is a pig of a job ?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Bobarache View Post
    This is the best way I can sum up my experience http://www.vectra-c.com/forum/showth...66#post1066266
    The How To here http://www.vectra-c.com/forum/showth...ighlight=spark seems straight forward enough but as far as I can see, you need to also disconnect the supply to the fuel rails and that doesn't seem to be mentioned. I might be wrong though.
    Jan 2010
    Durham
    I too have just found this same leaking problem. Iwas talking to a vauxhall tech and he recons that the rocker covers are plastic and warp and this is what i need to change. Phoning stealership today to see if any truth in this........Car stinks at present.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by vinceholt1 View Post
    Correct, according to the indy garage I use. Chap who does my GSi was a VX Master Tech for 9 years and he's mentioned in the past about the plastic covers. However, when he did my gaskets @ 72k, the covers were OK. If they hadn't been OK and only slightly warped, he reckons a good bead of sealant takes up the gaps.
    HTH
    Regular Member Jezzy's Avatar
    S.E
    There are two possible causes of this - both quite common. Firstly, as you say, the plastic rocker covers may have warped. Second reason may be that the oil breathers are blocked, causing excess pressure in the crankcase, and that pressure escapes by getting past the rocker cover gaskets, letting oil out as well. Have a read of these two How2s from an Omega forum. The step-by-step instructions will differ somewhat from your car, as the V6 is mounted lengthways in the Omega, but the principles are identical.
    Why the leak occurs:
    http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
    How to fix it:
    http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
    Jan 2010
    Durham
    thanks mate.. dealers want £136 worst case.. cover and gskt.
  1. Rocker cover
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 6th September 2012, 10:31
  2. Rocker cover 2.2 dti sri help please!
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 23:59
  3. 2.2 Rocker cover (types) - Intake cover removal
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 20:27
how long to change rocker cover gasket vectra c 2.2
replacement cam covers for vectra 3.2
vectra rocker cover replacement
Vectra zc v6 rocker cover gasket replacement
vectra 3.2 inlet manifold cover gasket
how long to repair rocker gasket on vectra
vectra v6 rocker cover gasket
