Results 1 to 10 of 11
Thread: couple of questions........
    Regular Member signum03's Avatar
    worthing
    confused couple of questions........
    evening all! i have a 03 plate signum elite auto 3.0 v6 cdti with a y30dt engine:
    1.i was told it a cvt auto gear box (knock to the left and can be used as manual, has mine got this, how do you find out?
    2.do i have xenons?again i was told it has but how do you know, there was a thread aroung a week ago explaining headlights but still not sure.help?
    thanks all!
    Regular Member david.aka.judas's Avatar
    Suffolk
    wtf on question 1 - try it and see.......... what you like........hahaha
    worthing
    sorry just re read not that clear! cvt is continual variable transmission, so gears are running at optimum level normal autos dont have this, just interested!
    worthing
    bump
    No idea on the CVT, I think what he meant was that the easiest way to find out if you gear change can be done manually (ie, knock to the left and select up or down) was to look down and see if your car has it...
    As for Xenons, no you don't have them mate. if you did, you'd be able to see where you were going...
    Suffolk
    lol on the 2nd point.
    11 Post(s)
    Quote Originally Posted by signum03 View Post
    2.do i have xenons?
    If you've not got a manual headlight adjust knob by the headlight switch, then yes.
    Also when you first switch them on, if they flash very bright briefly and then dim down before becoming bright again, then yes you've got Xenons (HIDs)
    Also, you'd have headlight washers, which looking at your avatar you don't... HID kit will give you xenons though - well worth the money...
    asdasd
    Could have had hids put in at some point..Thus not having headlight washers...Ull know if you got xenons its just one of those things..If there yelloww then NO if there blue then MAYBE..means either you got xenons or blue lights..Cant really comment without pics
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you look at the transmission selector you have the normal straight down run of positions. If then at the bottom you have an additional cut-out to the left of the main track that you can move the selector into, you might well find that you can push the selector forward and back and in each case it returns to the middle position. I believe this is what you were asking about in your original post. You would push forward to the + marking for a higher gear and back to the - mark for a lower gear. The system is called 'ActiveSelect'.
  1. A couple of questions.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 16:16
  2. Couple of questions
    By Pete1nlancs in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2010, 20:14
  3. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  4. Couple of questions
    By StephNET in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2008, 01:35
