Thread: No power between 3k-4k and high revs
    Aug 2007
    Exclamation No power between 3k-4k and high revs
    Hello,
    I have got petrol 1.8 vectra C and when i put pedal to the floor the car gets very high rpm without much power. It happens on every gear and it gets worse once car is warmed up. When i accelerate slowly the rpm increase normaly.
    please advice.
    Apr 2008
    Coventry
    I had a simliar problem with my Vectra 2.6 B, It turned out to be the MAF sensor. MIght be worth checking
    Aug 2007
    cheers bignew,
    Here is a thing. First i took my car 2 days ago to vauxhall garage. They had a road test and the guy said its definatelly slipping cluch and quoted me for 900 pounds. So I though f* y* and took it to HiQ same day. They came with fault in canvas wiring system. They cleared the codes and the car seems to perform much better. They told me i should take it to the electrician and they should solve the problem. I did that yesterday and they found nothing and didnt replace anything. So electrician told me to go back to the vauxhall and they should have better equipment so that they find out what exacly is wrong with a car. I am now booked for monday in vauxhall garage in a different town so they hopefully give me a honest opinion.
    What do you think guys? Is this might be a canvas wiring system? I hoping its not the slipping clutch because it will cost me around 500 quids :/
    Any advice please. Cheers
    Apr 2008
    Coventry
    Reading your description of your fault again it does sound like the clutch, I suggest going to a local clutch specialist before Vauxhall.
    Vauxhall dealers are the last resort IMA
    West London
    sounds exactly the same as what happened to myne when the clutch went, its also a 1.8 petrol.
    I got myne done by a local private mechanic cheap, but the lowest i got was mr clutch at around 300 squids all in.
    Aug 2007
    I wanna say also that I am sure my car has a power and when revs are between 3-4k then clutch is kicking in (slipping). Do you think it might be something else than clutch? Any other suggestions guys?
    Aug 2007
    I need another suggestion from you guys before i go with replacing clutch. Thanks for any answers.
  1. high revs
    By andy_richmond in forum Engine & Drivetrain
    Last Post: 12th October 2012, 18:43
  2. high revs no power
    By veccyDaz in forum Engine & Drivetrain
    Last Post: 29th May 2012, 18:31
  3. Vectra Sri 1.9 150 No power until high revs
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 17:35
  4. Loss of power - high revs
    By ac14 in forum Engine & Drivetrain
    Last Post: 19th March 2012, 22:11
  5. Can you Help ~ Loss of Power, High Revs
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:23
