Results 1 to 2 of 2
Thread: Need urgent help
    Sep 2009
    staffs
    Exclamation Need urgent help
    My dads 2006 vectra 1.9cdti (120) has a problem. He was out in it the otherday and the alternator light came on. He then used it the following day to go to work and drove without problems. Upon leaving work he tried to start it.....and nothing. Recovery were called out and they checked the alternator and said that it had gone. We ordered a new alternator and fitted it yesterday. After fitting it, it drove fine until the following day. On starting it afew more light on the dashboard lit up including the maintenance/service light. Luckily we knew 2 local garages who put it on the diagnostics and both came back with the fault code: P1125 which is a throttle actuator fault. Everywhere we called has advised us to contact a main dealer but as the car is now well outside of its warrenty, i was hoping someone on here may be able to tell me exactly what the problem is so i have an idea before i go to the dealer. Could this be a fix that we could do OR does it have to go to a dealer??
    Sep 2009
    staffs
    Quote Originally Posted by cbetts2005 View Post
    Forgot to mention. Currently the car starts up fine but doesnt idle very good, has even cut out numerous times. Also anything over 3000rpm makes the revs eratic! There just seems no power in the engine at all.
    Does this sound about right for a 'throttle actuator' fault?
    What actually is the throtle actuator?????????
  1. Urgent help with 2.0t .....I'm under it now
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 18:28
  2. Urgent help!
    By Kieran1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2009, 19:17
  3. urgent
    By jones20002uk in forum Engine & Drivetrain
    Last Post: 21st April 2008, 17:10
  4. Urgent help please
    By EARLEY in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:46
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
