Thread: Driver side electric window stopped working
    Regular Member danlat1415's Avatar
    Lancashire
    Default Driver side electric window stopped working
    Has anyone had any problems with their electric windows stopping working, and any ideas what the fault could be?
    They were working fine up until today, when I've got in car as normal, and pressed the window down switch on drivers side. No response. I can hear a 'double click' when I press the UP or DOWN button, so I don't think it's the switch not working completely.
    I've tried manually 'helping' the window the window down (holding hand flat against window, and trying to slide down) when I press the button to see if it's just stuck, but that doesn't help.
    Does anyone have any ideas what it could be before I start ripping the whole door card off and having a mess around..
    Dan
    Regular Member garvey's Avatar
    Co Durham
    could it be the mechanism snapped.
    Lancashire
    any idea how much it may cost for a part?
    Devon
    Default Electric window fault: DIY, dealer or any garage?
    Today my driver side electric window stopped working. It did a few shudders and then a loud crack
    Is this a DIY job, a definite dealer one or could you go to any garage?
    I guess something snapped (motor attachment to window?).
    Any ideas about costs when going to VX?
    Thanks,
    Mark
    Worcs/Staffs/Westmids (ish)
    The windscreen guys will also do door windows, or at least they used to.
    As for DIY there's bound to be a guide on here somewhere for dismantling the door.
    Mar 2011
    Shropshire
    This happened to me too 2 years and 80000 miles ago on my 2007 Vectra C. Got around to buying a new motor and mechanism on ebay for £25 - there are a few out there so it must be a common fault. Intend to replace it after reading on how to remove the door lining on this site. Windscreen companies I tried were not interested as the glass was ok. Perhaps a hammer attack might get them to repair it.
    Feb 2011
    barnsley
    My drivers side was exactly the same when i bought my Vec!! Wouldn't go down but you could here it click when you pressed the up button.
    I took the switch out of the door panel, too the switch apart & cleaned all the contacts. Put it all back together & it's worked fine ever since!! took me about 5mins from start to finish!
  1. Driver side window and mirror not working
    By j2cams in forum Bodywork & Interior
    Last Post: 3rd April 2011, 21:51
  2. front passenger electric window control stopped working
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 10:47
  3. Driver side electric window stopped working
    By danlat1415 in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2009, 23:05
  4. Window wiper stopped working
    By Darryl2.2DTI in forum Bodywork & Interior
    Last Post: 8th February 2009, 18:50
vauxhall vectra drivers window not working
vauxhall vectra electric window fault
vauxhall vectra windows not working
vectra window wont go up
vectra window problem
vauxhall vectra electric window problems
drivers window wont go down vectra
vauxhall cavalier electric window just clicka
vectra c window stuck shut
electric windows stuck in down position Vauxhall vectra
electric window on vectra wont go down
2008 vauxhall corsa drivers side window stopped working
electric window fault vauxhall vectra
electric window not working on a vauxhall tigra 2005
Vauxhall vectra window works but wont move
opel corsa c electric window ecu how it works
window wont go up on a vauxhall corsa 08
2007 vectra drivers window not going down
vauxhall vectra electric window mechanism
2008 vauxhall tigra drivers window stuck down
signum front window just clicking
https:www.vectra-c.comforumshowthread.php92397-Driver-side-electric-window-stopped-working
vectra passenger door electric window not working
vectra c electric windows not working site:www.vectra-c.com
sticking window motor vectra c
