Thread: engine swap
    CARDIFF
    Default engine swap
    hello guys (and ladies) new to site so be gentle. got a 2 ltr dti engine code y20dth. it went bang two weeks ago and its terminal. i,ve sourced an engine out of a vectra b, same engine code. will this fit my car or not ? i know i,ll need to change the diesel pump and maybee the wiring is slightly different? any knowledge on the subject would be great.
    Someone was messing around with 2.0 DTi's a few months ago mate, ask admin if they can edit the title to include this and you've more chance of someone having a nosey aound...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You would need your pump as there coded to the car I believe. The last guy who did the swap had big problems just from the pump alone. Thats my little 2ps worth mate, as Penfold said the title could do with a change to get more interest.
    Regular Member garvey's Avatar
    Co Durham
    I am on my 3rd y22dtr engine everytime just changed pumps and no other problems
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi mate yes they fit as ive put a vec b into a vec c just change pump fly wheel couple of bits but they do fit 100%
    Leicester
    It's quite simple, all you need from the Vectra B is just the engine itself. Bin the Vectra B managment and the ancillaries.
    Once you have removed your own engine, swap over all the hardware and ancillaries from your knackered engine to the replacement and drop it back in. There won't be any wiring modifications as your using your existing management system from the Vectra C.
  1. Engine swap
    By dti owner in forum Troubleshooting
    Last Post: 27th October 2012, 15:46
  2. Engine swap over
    By dti owner in forum Engine & Drivetrain
    Last Post: 27th October 2012, 13:18
  3. engine swap
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2011, 20:57
  4. Engine Swap
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 15:51
  5. engine swap
    By CDTIsteve in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 18:35
y22dtr engine transplant vectra c y20dth
2.0 dti engine swap
motorswap opel vectra c naar vectra b
y22dtr engine swap
