Thread: help please
    Regular Member andy76's Avatar
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    Unhappy help please
    just looked at front wheels as somthing knocking on drive so needed to look at what is catching and found fluid/oil....
    took these pics from the drivers side front wheel.
    so now all im seeing is ££££££££ is it a drive shaft or somthing else any one know., and how much it is going to cost to sort, got mot in 2 week.
    May 2008
    Tyneside
    Thats the driveshaft inner CV joint boot split. If your lucky the joint may be OK and just require a new boot fitting. Would think about £50 fitted from an independant garage.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by tridley View Post
    but get it done quick or else it will dry out and cost you even more...
    May 2008
    Tyneside
    Just read your post again, sounds like you need a new joint if its knocking.
    sheffield
    Vehicle : cdti 150
    Trim : sri
    Engine : z19dth
    if it is knocking will it be expensive, also (hoping it's not) can having coilovers fitted have caused it.
    thanxs for the help
    Mileage : 000
    If it is a "stuffed" CV joint try it on full lock you might find there is a rumbling noise. Unless you have been driving it for quite a while I doubt it if it is the CV joint, that is making the noise. On the wifes Vectra B the driveshaft gaitor split and there was quite a lot more greas splattered about than on your photo. But I spotted it qiuckly and replaced it and there was no noise and the CV is still ok now.
