View Poll Results: brush or roller......
Voters
15. You may not vote on this poll
  • use the roller as its quicker
    8 53.33%
  • use the brush as its a better finish but takes longer
    2 13.33%
  • get some in to do it
    5 33.33%
Results 1 to 10 of 13
Thread: decorating..........
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default decorating..........
    i know its a nasty job but im still on with painting the inside of the house
    having problems with bits of fuzz coming off the roller and getting stuck in the paint
    has anybody got any tips to stop this happening? ive tryed using the old brush but seens to take a life time to just do one wall then it malts when it wants.....
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    hey bobby
    there is a lot to be said for using good quality rollers (harris etc)
    it is imperative that before using the roller you rub up and down it (a little like a sign you might use at some one you don't care for very much) if you catch my drift,.. then with a wet hand repeat,.. this should remove any loose fur,.. also check that the roller is no fluffier than is needed for the job, hope this helps,.. hate paintin and i've dne a lot
    WGAF#5
    get a paint pad - fine bristles and quicker to apply...good at cutting in- doesn't soak up the paint,the coverage goes further no paint spatter up your arm from using it ...
    or you could just drop a grenade in a paint tin - vacate the room wait for the bang - job done
    Regular Member denzilbud's Avatar
    cambridge
    invest in some good quality rollers and you wont have this problem mate
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Quote Originally Posted by denzilbud View Post
    how much should i be expecting to pay for a good quality roller?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I second paint pads mate. Although personally i hate decorating and if i had the spare cash would just pay someone to do it!
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    I third the paint pads. No fluff, streaks and really quick.
    Or try THIS.
    Paul.
    Snowman, you got your ears on?
    Mileage : 000
    If you are painting the walls. I recomend a paint pad. They are brilliant. I find with a roller no matter how carefull I am, I always end up looking like a badger, with the paint that has "flicked" off.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i would recommend a good quality roller........about £8 the replacement ones,not the cheap B&Q ones for £4
    Plymouth
    I fourth the paint pads...
    No mess and ALOT quicker!
  1. Non Car Poll! - Decorating The Kitchen
    By Leemarksmith in forum General Chat
    Last Post: 17th October 2010, 11:28
  2. An ideal day for decorating
    By ed taylor in forum General Chat
    Last Post: 18th November 2007, 19:11
  3. More Decorating
    Last Post: 4th November 2007, 16:22
  4. Took a day off from decorating
    Last Post: 12th August 2007, 08:10
  5. Decorating
    Last Post: 8th August 2007, 11:28
