Thread: HELP. Struggling to Start
    Plymouth
    Default HELP. Struggling to Start
    Ive noticed recently the car is struggling to start.
    It seems to happen more often when cold and when parked on a slope where the back is lower than the front.
    This afternoon it to around 10 turnovers, and then another attempt of 3or 4 turns before it would start.
    I dont think its the battery as it turned over ok and didnt seem to struggle..
    Any ideas guys n gals.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Leak off pipes??
    Plymouth
    Leak off pipes??
    if i looked at them would they be messy??
    Also any tools needed to take the cover off to look?
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Diet - look through http://www.vectra-c.com/forum/showthread.php?t=59573
    I've got the 2.2DTi and had starting issues, everyone says "don't park uphill" which actually is true, and on mine I can't let the fuel in the tank get below 1/4 tank.
    I think changing the leak off pipes is the first and cheapest thing to do, I did attempt to do this but it looked way to fiddly ie: tightly fit in tiny gaps, so thought I may cause more of a leak than fix!
    Three weeks ago I was down to 1/4 tank, and on a slight incline, and it wouldn't start, nearly killed my battery, but as suggested on here I got my mate to tow me down the road, clutch up in second gear and within 25' it started!!! Straight down the local Esso to fill up and not caused any trouble since.
    Being a 2002 diesel when I bought it I assumed it was built in the 21st Century....
    Plymouth
    Quote Originally Posted by si_hoss View Post
    Cheers mate.. I will try parking downhill 2moro and see if that works Then it will be a case of looking round the leak off pipes and seeing if there is any gunk etc etc
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Try replacing the fuel filter housing cover.
    Plymouth
    Ok had a good look roudn the leak off pipes.. all clean and no signs of leaks etc.
    Basically if the car is left for a few hours it wont start the first time u try.. It keeps turning over but never 'fires' up Doesnt matter how long i let it turn over for.
    Yet, when i go for another try again it starts up on the first or second turn over...
    Any More ideas what it could be?
    Regular Member Swaite53's Avatar
    South Wales
    Could it be the starter motor not engaging properly
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Sounds like classic glow plugs...try ignition on for 5 secs, off and key out then ing on again and see that helps. Not sure if the cold start circuit is timed though.
    Plymouth
    Quote Originally Posted by Swaite53 View Post
    Hope not!!
    Quote Originally Posted by Telly Addict View Post
    Arn't they supposed to last for 80k Miles...??? As Its only done 40k
  1. Struggling to start after re-fuelling
    By Bloicy 3.2 V6 GSI in forum Troubleshooting
    Last Post: 1st August 2011, 18:50
  2. Struggling at 1st base
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 18:58
  3. Struggling... need some help please...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2007, 12:53
