Thread: Odd "Water Noise"
    Darlington
    Default Odd "Water Noise"
    Hi
    Vectra 06 Facelift 1.8 Petrol
    Hi
    When @ tick over there is odd noise what can only be described as water "burbling" as if running through pipes somewhere - increase the revs and its not noticble or has stopped.
    its allmost like putting your ear to a house radiator and listing to the water going through or better example the noise a washing machine makes when its emptying the water through the waste pipe at the back. but only very slightly.
    A odd noise i know but does anyone have any ideas - many thanks
    Regular Member Gortreck's Avatar
    Sep 2009
    Newcastle Upon Tyne
    My fiance has a Fiat Punto, that sound was the cylinder head gasket not functioning correctly on her car
    Darlington
    so the cylinder head casket has gone? the car has only done 25k
    Mileage : 55000
    I think one or two members have mentioned this noise. But I don,t think they "came back" to say that the head gasket had gone.Does it make this noise all the time, or is this the first time you have noticed it.
    Darlington
    two days ago was the 1st time that i had noticed it, this morning it wasnt as noticble as before i havent checked any levels on the car yet only to say that temp sits in the middle of the car and the low oil level light goes out (not to be confused with the low pressure light)
    Mileage : 55000
    I would keep an eye on the fliuds. But you might find you don,t hear this noise for quite a while "if ever" I don,t know what it is. Possibly an air lock, that will clear it,s self.
    Darlington
    ok cheers Ed, ill check out the levels, if everything ok ill just keep a eye on it
    If the levels are fine, there is no smoke coming out the back and it runs fine - then ill just keep a eye on it, as it all indicates that the head casket is fine
    Jun 2009
    doncaster
    mine does that,its the thermostat opening,its done it for two years, nothings happened, so its normal dont worry!! and its a 1.8 petrol as well!
    Regular Member grumpano's Avatar
    North West
    My wifes Mini used to do that we tried everything,bleeding cooling system etc. It turned out the problem was down to a slight leak in the thermostat housing.
    Darlington
    Hi Thanks for all your replys, ive checked all levels and its fine - so if its normal then ill just keep a eye on it - thanks again
  1. loud "thunk" noise from passenger side suspension
    By Gordon Livsey in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2010, 15:14
  2. "clunk" noise when taking foot off brakes
    By sdnatlst in forum Handling & Braking
    Last Post: 21st May 2010, 19:13
  3. Water "swishing" noise
    By CDXI_2003_AUS in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 14:33
  4. 1.9cdti - high idle speed and new "noise"
    By mossie in forum Engine & Drivetrain
    Last Post: 7th October 2008, 16:12
  5. Vectra 2.2dti "grumbling/knocking" noise
    By Peetoki in forum Engine & Drivetrain
    Last Post: 17th February 2008, 14:51
