Thread: Brake pads 2.2DTi
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Default Brake pads 2.2DTi
    Afternoon, a colleague of mine has an 03 plate 2.2DTi SXi. He recently had the front brake pads replaced at Kwik Fit and ever since he's getting the brake pad warning light on the dash. Kwik Fit assure him that they've checked the sensor and that the new pads are fine. He doesn't know if genuine GM pads were fitted or not.
    Anyone know if this is down to the pads used or does something need resetting via the Tech2
    Hertfordshire
    Probably the sensor m8, they are apparently quite fragile.
    Nicking Ya Dinner.
    Na, they are nothing to do with tech 2, it's simply a wire in a plastic sheath that wears away to put the light on, they either haven't put a new one on, or they have thrown the old one away and not replaced it, if he needs to have a look, it should be on the drivers side front caliper, if there's no wire going to the caliper then you will need to get one, I think motor factors do them now as well as Vx, if it is there still and worn, snip the end off and twist the two wires together to make the circuit again and tape it up and tuck it away.
    Dec 2005
    In the sponge-monkey tent
    I had this after a recent pad change, with some advice from the guys here I changed the sensor myself. It was about £10 from the stealer who said they carry a stock of these as they're so delicate. He said even their own Master**** fitters break them from time to time. It's really easy to change as well.
  1. brake pads
    Last Post: 31st July 2010, 10:16
  2. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  3. Brake pads
    By L11Marc in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2010, 23:19
  4. brake pads
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2009, 22:25
  5. EBC Brake Pads
    By andy13 in forum Parts for sale
    Last Post: 26th June 2008, 16:44
