Results 1 to 10 of 11
Thread: Power steering problem
    Jul 2009
    gloucester
    Angry Power steering problem
    I have a 2.2 elegance and I have a problem with the power steering,the warning light has come on and the steering gets light at high speed,have had it on a diagnostic and nothing came up, is ther a speed sensor?
    has any one had this problem
    Steve
    Regular Member old cruiser's Avatar
    slough
    Have you checked the power steering fluid level?
    Cheers Pete
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    these pumps are electronicly run, and if the fluid level is ok, then it might be the pump or the cim
    Jul 2009
    gloucester
    Fluid level is ok,What's a cim
    asdasd
    This happens to mine..Had a new pump fitted (2nd hand one) after my one failed..Mine goes Hard when i do manoeuvre (dont how to spell it).Light comes up on diagnostics clear codes nothing happens..
    Regular Member garvey's Avatar
    Co Durham
    I had light come on with faulty sensor.
    Full Member Big Sig's Avatar
    Quote Originally Posted by scooter boy View Post
    Part of the cars canbus
    Regular Member Stuarty's Avatar
    Aberdeenshire
    I sarted up the vec today and i had a warning light of a steering wheel with an exclamation mark through it so tried to turn the steering wheel and had no power steering turned the car off and on again and all seems fine now hope theres not a serious problem lurking round the corner!!
    11 Post(s)
    Quote Originally Posted by Stuarty View Post
    Did you try revving the engine to see if the PAS would start working? If the battery voltage is too low then it can affect the PAS as it uses an electric pump.
    Aberdeenshire
    No i didnt try revving the engine il try that if it happens again.
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
opel vectra c 2.2 elegance power steering
