Thread: 3.2 v6 tuning
    Regular Member David Dixon's Avatar
    Sep 2009
    County Durham
    Default 3.2 v6 tuning
    ok people here's my first bunch of question....
    seeing as i have had nothing to do with the 3.2 engine yet can you people tell what mods can be done? like changing the oil cooler to a air to oil cooler, is there anyone that does exhaust manifolds? can the standard ecu have the immobiliser removed? does anyone like piper do high lift cams for the 3.2?
    there's probably loads of things so anything you know please tell me, thanks in advance
    Sep 2009
    County Durham
    anyone?
    Try asking courtnay sport or Regal
    Oct 2009
    bristol
    lmf now do equal length stainless mainifolds for the 2.5 but i think they will fit the 3.2.
    at the end of the day all the vauxhall v6s need improved inlet and out let and uprated plugs leads and fpr
    The 3.2's don't have ht leads
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Hello mate.
    I have a 3.2 too and looking at some mods. Someone mentioned in one of my threads that Total Vauxhall have an article out next month about 3.2 tuning so i'm holding some hope for that.
    I also looked at a remap. BSR unfortunately cannot help. Regal can but they're down in Southampton I believe so have tried Torquing BHP.
    Don't forget the Supercharger conversion...
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Mite be silly but here goes......
    I was told by an ex Corsa GSI Owner/Modder that because Vauxhall import cars from EU they have restrictors in the main wiring loom. A fuse of some type that can be taken out and replaced backwards?
    He said it gave the Corsa around 30 bhp....
    Anyone have any imput on this?
    Sep 2009
    County Durham
    its mainly the block and heads that i will need tuning because its going to be ran on vectra b gsi inlet and ecu....its going in a nova;
    the exhaust manifolds was one of my first things to look at, i would like equal length manifolds, i'll check lmf for that one as someone mentioned it, plugs and leads will be uprated to grade 8 ngk-r's from a escort rs turbo, leads probably magnecor 8.5mm's.
    does anyone know what the small hole is for below each exhaust port? can that that be machined out to make the ports more level? i notice the cams are g's in the inlet and j's in the exhaust..... will the piper 3.0 fast road cams have more lift and duration than these?
    cheers david
  1. TDI tuning - tuning box thoughts so far...
    By nichols120 in forum Diesel Engine related
    Last Post: 4th February 2012, 20:48
  2. tuning box or not to tuning box that is the question
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:47
  3. need help with tuning box
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2010, 19:49
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
vectra c 3.2 uprated fpr
vauxhall 3.2 v6 engine tuning
