Hi guys.
Update on the manifold situation. The dealer have agreed to reimburse me £220 of the money i've paid to the car, which is fine with me.
They have also agreed to take the car in and investigate the manifold. I need to be an expert on this problem so i can tell them everything thats wrong and make sure it gets fixed properly. The garage i got it checked at told me the inlet manifold needs replaced, but theres a few things i need cleared up.
The bar behind the fuel rail has broken off - but what does it do?
What are the 4 rubber looking holes for? Should the bar be attached to these?
The oil light came on the other night and it was nearly empty and i noticed a lot of oil around the third and last hole where the bar is (counting from the left)
Any help would be much appreciated as i said, i want to make sure i show and tell them everything.
Also, theres a huge flat spot when it changes between second and third and the car also jerks violently sometimes. Is this down to the manifold problem?
Here's a few pics
The oil is around these 2 bits
