Results 1 to 10 of 11
Thread: Inlet Manifold
    Larkhall
    Default Inlet Manifold
    Hi guys.
    Update on the manifold situation. The dealer have agreed to reimburse me £220 of the money i've paid to the car, which is fine with me.
    They have also agreed to take the car in and investigate the manifold. I need to be an expert on this problem so i can tell them everything thats wrong and make sure it gets fixed properly. The garage i got it checked at told me the inlet manifold needs replaced, but theres a few things i need cleared up.
    The bar behind the fuel rail has broken off - but what does it do?
    What are the 4 rubber looking holes for? Should the bar be attached to these?
    The oil light came on the other night and it was nearly empty and i noticed a lot of oil around the third and last hole where the bar is (counting from the left)
    Any help would be much appreciated as i said, i want to make sure i show and tell them everything.
    Also, theres a huge flat spot when it changes between second and third and the car also jerks violently sometimes. Is this down to the manifold problem?
    Here's a few pics
    The oil is around these 2 bits
    Full Member Big Sig's Avatar
    Swirl flaps/valves. That bar is the actuator for the swirl flaps, yes it should be attached to those bits you describe. This being U/S would lead to your flat spot.
    Larkhall
    I took the car to the dealer this morning and they just phoned me saying it's been on a road test, and suprise suprise, there's nothing wrong. The guy said it drove fine, no fault codes and the manifold is fine. He said the valves move freely and the link rod can be put back on and it will be ok, but they will get an independant inspection done next wednesday........
    So i phoned the place where i got it diagnosed and they said the rod can be put back on but it will just come off again - the manifold is knackered and it needs replaced.
    The finance company said i need to wait till the dealer get their inspection done before they can do anything.
    Larkhall
    Their fix didnt work so the rod came back off and ive got on to the finance company yet again
    Ive seen a few members who have fixed the rod on themselves and just wondered if the rod gets attached to the nipple parts on the manifold or over the 4 holes
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    nipples!
    May 2006
    scotland
    Quote Originally Posted by T4M View Post
    Rod, Nipples parts and 4 holes in the same sentence. Too much for me, im off!!!!
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    you can reattach the rod you mentioned bud some members have found a cure but thats just to save them money cos its not cheap to replace the manifold. the place that told you the manifold is knackered is correct mybe you should go back to them and get a written explaination of what they think the problem is. im quite surprised by your dealer they know this fault exsists and would be happy to get the work ie someones gotta pay em
    Larkhall
    Quote Originally Posted by plasma View Post
    nipples!
    Quote Originally Posted by wickedwillie View Post
    ha ha bunch of kids lol
    if someone had a rod, 4 nipples and 4 holes i'd be quite scared!!!!!!!!
    i phoned the finance company today who said the dealer told them they haven't yet recieved the independant report yet............ but when they told me the car was ready the mechanic told me the independant said the same as him - that it was fine!!!!!!!!
    anyway i'll keep chasing them
    Are you VXR Enough
    13 Post(s)
    you keep chasing em bud
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Chris is correct...
    Also - the reason the bar has come off is due to excessive up and down movement of the flaps.. this in turn wears the ball joints and the bar falls off.
    Also - the up and down movement means that the flaps are not sealed and caused gunk to escape past them etc and also gum up..
    There is a PDF from the makers of the inlet that explains and you can use that to send to the finance / warrenty company... Let me see if I can find it..
    A
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
