Results 1 to 10 of 19
Thread: Car refuses to start! Help!
    Default Car refuses to start! Help!
    Sorry to start another thread but ive got a big problem. I taken the inlet manifold off to clean it, to do so i had to take off the 4 injector pipes... and now the car just wont start..
    Im scared that if i keep cranking the car it may damage the fuel pump.. i have been trying for about 20 mins in short burst of 10 seconds but no luck ( battery died, on jump leads), is it ok to carry on until it starts? if not what are my options..
    i ve made sure the union nuts are tight, all pipes and screws tight! done all the checks but seems theres just too much air in the fuel line, infact i full tanked the car just before the job to limit the air intake..
    can someone please advise me, im gettin rather worried
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    i take it is a dti ,if so tow start it in 3rd or 4th gear , i wouldnt keep cranking it ,if you can fill the fuel fillter housing with a jar of diesel
    yes sorry its a vectra c 2.0 dti 04 plate, Thanks for the reply, im not quite with you on the tow start, basically the cars being towed and i would try and start it on forth gear, if theirs air in the system would it start though.. i mean the air needs to somehow needs to be relleased?
    Don't you crack the unions off while cranking it to bleed the air off from the pipes...?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    you can crank the engine for 40 seconds with a 20 second rest for 3 times,vx then advise fitting an external fuel pump to bleed system ,dti's are renowned for bad first start after a fuel drain
    Aug 2007
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    Quote Originally Posted by siz1 View Post
    yes this should bleed the system
    oh my, how do i go about fitting an external pump!! the other option it to get towed and then try and start in forth gear as suggested, could i possibly do this with the AA or RAC?
    do the unions needs to be on or off from the injectors, i noticed that quite abit of fuel leaked out from the unions...
    by the way does the speed matter when trying to bleed the system on forth gear? would i be turning a key or simply lifting mt foot off the clutch? i hope rac will tow it
    any ideas of an external pump?
    i really need my car back now..
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Get towed to a slight hill.
    Into second, keep the clutch down and as you get up to a speed (let's say 20mph) start to pray it will start when you dump the clutch
    That's how I brought ours back to life.
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Troubleshooting
    Last Post: 7th September 2010, 13:02
