Thread: CCR2006 stuck CD
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Default CCR2006 stuck CD
    As the titile suggests, the little 4CD mag in my ccr2006 has become well and truly stuck,.. won't play cd's nor will it eject... little door opens but mag stays put,.. screen says error but no help.
    Any one lse had similar problem or suggestions?..
    Not that keen on the brute force option
    WGAF#5
    remove the unit and then remove the top cover - you should then be able to "manually" wind the gear cogs - i suspect 1 cd has become jammed on the loading mechanisism so it cant complete its cycle -once you have manually wond the mechanisim either back to the start of to the end then lubricate all of the gear cogs with a light silicone grease and plug it back in and retry
    on a small note if you can see excessive wear to the cogs then i suspect that it wont help greasing and a repair/replacement unit might be the order of the day
    regards
    Dez
    Aug 2009
    Frinton on sea
    cheers Dez
    Well off to have a crack at that then,... any thoughts on how hard this is?
    looked at the how2's for an idea, not much goin on for the 2006.
    oh well off i go...
    WGAF#5
    hopefully (he say's with fingers crossed) not too bad
    the top cover will probably "pop" off or may be held on by a few torq screws - the loading mech should be similar to a VHS video unit and these were belt/cog driven - once you open her up if you get stuck post a piccy and i will see if i can point you in the right direction
    regards
    Dez
    Aug 2009
    Frinton on sea
    Ha ha
    well, took out little grub screws on fascia,..
    wasn't coming off at all easily... had little flap open to try and prise fascia off and lo and behold out pops the CD magazine
    BTW it's been stuck (with various attempts to extricate it) for a week
    Cheers for speedy response none the less
    WGAF#5
    Quote Originally Posted by P-Mutton2.2 View Post
    Ha ha
    ha ha - i would say its still worth removing and having a "lube" to prevent future misfortunes
    good news though !
    regards
    Dez
  1. CCR2006 CD Magazine Stuck
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 13:28
  2. ccr2006 again
    By chaz851 in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2011, 11:15
  3. Swirl Flap Stuck or Not Stuck ??
    By nibblitz in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 17:57
  4. Ccr2006
    By Elevonic in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 18:53
stuck cd in vauxhall vectra
