Thread: Possible causes
    glasgow
    Default Possible causes
    had my 04 1.9 cdti vec (120) in 2 garages from last wk. it went into limp mode last monday on way to work left it all day drove home fine then later that night went out n after 3 miles limp mode again,
    1st garage diagnosis mite be fuel pump then next day dont have a clue
    2nd garage put it on diagnostic machine n no faults appeared
    when i started it drivers indicator light came on n stayed on n brake lights wer lighting up different wen i braked so got that fixed, guy from garage said sumthing about maybe loose wiring was causing brake lights to come on n causing car to think it was breaking n trippin sumthing making it go into limp mode
    could this be true or is he jus talking out his butox?
    drove the car for 3 miles on way home n was fine will take it out longer tonite to see if it happens again
    Blantyre
    1: Have you checked for any split hoses,
    2: Is there not a brake actuator switch under the pedal, maybe this is is knackered and needing replaces, if its causing the lights to come on
    have you checked for any faulty earth connections, have you installed anything lately electrically maybe ?
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Check the engine earth leads, and while you're at it the battery terminals. Bad engine earth can cause all sorts of weird problems.
    glasgow
    brake lights seem to be fine now, not noticed any split hoses but al give it a better look tomoz its getting a bit dull now,
    dunno how to check for faulty earth connections
    not given it a run in yet so dunno if its still goin into limp mode as it ran fine for couple of miles before it did beforehand
    cheers for ur quick reply spenny much appreciated
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by jamie78 View Post
    spenny strikes again lol hes a top man
