Thread: Help....can't find crankshaft sensor on 2.2dti
    Sep 2009
    Bo'ness
    Default Help....can't find crankshaft sensor on 2.2dti
    Hi people......I have a 2004 2.2dti signum with an auto gearbox. I need to replace the crank sensor as the rev counter is sometimes hunting and engine also cuts out sometimes when idle. According to TIS2000, the crank sensor should be somewhere close to the oil filter, and that it's plug is just beneath the vacuum solenoid to the passenger side of the rocker cover.
    Unfortunately, I have looked and looked and can't seen to find the crank sensor anywhere. Can anyone please point me in the right direction as I am absolutely lost!! I have found a sensor on the rear of the bellhousing next to the gearbox relays - this looks like a crank sensor, but it looks nothing like the replacement I have just bought.
    Any help much appreciated.
    thanks,
    Daniel
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    remove upper engine cover the crankshaft pulse pick up wiring harness is just to the right of the oil filter housing facing up,unplug the harness,jack up vehicle make sure you block it up.remove service flap from under engine ,pulse pick up is is fastend with a single bolt to the bottom of pick up remove bolt and pull down cable.fit new seal ring and coat with silicone tighten bolt to 8Nm,refit is reverse of removal good luck
    Sep 2009
    Bo'ness
    Cheers.....will try that out tonight then.
    Anyone has any idea what the sensor on the passenger footwell side of bellhousing would be then? Is it something to do with the autobox?
    Thanks once again,
    Daniel
    Jul 2009
    Engine : 20 Dti
    the transmission input and output sensors are on the upper part of the transmission,the output sensor is the one nearest the engine,the fluid temperature sensor is on the lower part of housing
  1. crankshaft sensor
    By liam8282 in forum Engine & Drivetrain
    Last Post: 18th September 2011, 13:29
  2. crankshaft sensor
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 20:36
  3. crankshaft sensor on v6
    By hugh in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2009, 15:58
  4. Crankshaft Sensor
    By rhodod in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2008, 23:21
  5. Crankshaft Pulley Removal 2.2DTi
    By Paul from Derby in forum Engine & Drivetrain
    Last Post: 26th April 2007, 13:21
vectra 2.2 dti crankshaft sensor location
where is crankshaft sensor vectra c 2.2
were is crankshat censor on vectra 2.2 dti
location camshaft sensor vectra c 2.2 diesel
2009 diesel opel insignia crankshaft sensor location
2.2 dti vectra c camshaft sensor
vectra c 2.2 dti hav a cam sensor
Vectra 2.2 2005 crank sensor location
where is the crankshaft sensor located vectra c 2.2 petrol
opel zafira 2005 2.2 camshaft sensor location forum
frontera dti crank sensor
2.2 dti sensor
opel zafira 2.2 crankshaft
chrankshaft sensor opel vectra c 2.2 diesel
vauxhall vectra crankshaft sensor location
crank sensor vauxhall frontera 2.2 d
vectra 2.2 dti crankshaft position sensor
opel zafira 2.2 crankshaft sensor location
omega 2.2 dti crank sensor location
vauxhall vectra c 2.2 dti crank sensor location
vectra c 2.2 dti crankshaft sensor location
https:www.vectra-c.comforumshowthread.php92199-Help-can-t-find-crankshaft-sensor-on-2-2dti
vectra c 2.2 dti cam sensor
