Results 1 to 10 of 15
Thread: 1.8vvt owners please respond
    Oct 2007
    Mid Wales
    Default 1.8vvt owners please respond
    I bought a 2006 1.8 vvt vectra from a dealer. It was juddering in reverse and so after some fuss they replaced the flywheel and clutch. Now its still doing it, but they say they've tried other 1.8vvt vectras and they all do it! Their explanation is that the reverse gear is slightly too highly geared so when reversing its like trying to pull away in 2nd gear.
    My symptoms - judder on reverse only, forward gears fine, much worse under load eg reversing up slight incline or with car full of people.
    Have any other Vvt owners got this problem?
    According to the garage EVERY 1.8vvt is like this so please let me know.
    Cheers lads
    Essex
    Hi mate, sorry to hear that got the 1.8 myself and can't say its juddered once in reverse always been smooth, so it doesn't cover everyone and i'm sure others will be along with and without similar symptoms.
    Regular Member Bethan39's Avatar
    South Wales
    Mine is on 27000 and no mine is fine forward backwards and with a full load no problems here! sorry to hear about yours
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    What a complete and utter load of twoddle!
    I've got a 2006 vvti which has just hit 50,000 miles and no juddering in reverse at all. It does it on the very odd occasion in 1st but never in reverse.
    Sounds like a dealer that can't be bothered to me. Tell them that you'll be speaking to Vauxhall Customer Services unless they rectify it.
    Fingers crossed for you.
    Paul.
    Snowman, you got your ears on?
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Like Pauls, once or twice in 1st gear, but never in reverese.
    Mine is an earlier 1.8 Non VVT, but gearbox etc should be the same.
    There was a problem with judder on 1.8's going back a couple of years ago.
    kilmarnock
    i too have a 2006 1.8 vvt and mine was juddering sometimes when pulling
    away and worse in reverse, fitted a new clutch and it cured it but 10,000
    miles later it started it again..... ive learnt just to live with it......
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    no juddering from forward or reverse in mine mate
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Reverse up a short incline every night - mine's OK.....
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    2006, 37k on the clock, does it sometimes when engine cold in 1st, but not noticed it in reverse?
    Jul 2009
    Newcastle
    I have a 2006 signum with the 1.8vvt engine and no judder on reverse. It has about 25K on the clock and runs as smooth as a babys bum in reverse. I do get the odd judder in 1st gear, but that usually cos I lift the clutch without enough acceleration.... opps
  1. Clutch slow to respond
    By DNS in forum Engine & Drivetrain
    Last Post: 13th February 2012, 18:13
  2. Slow to respond fuel gauge
    By rockonoli1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2011, 09:15
  3. Some info required as i cant seem to find it using search. 1.8vvt owners
    By Chris Nock in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 16:07
  4. koni owners please respond
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 08:44
vectra 1.8 vvt slow 1st gear
