Results 1 to 10 of 24
Thread: Fault Codes V6 CDTI
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default Fault Codes V6 CDTI
    Could anyone give some pointers as to what could be causing the following fault codes?
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0460 Fuel Level Sensor Circuit Malfunction
    P1566 Speed Control Command Switch Out of Range Low
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Does your car still smoke mate?
    P0400
    That is most likely to be the EGR valve that has failed
    P0460
    That is most likely to be the fuel tank level sensor
    P1566
    That is most likely to be the accelerator pedal sensor
    The first one is going to cost you between £150 and £200, but the main issue there is you may need to wait up to four weeks as there is quite a backlog of outstanding orders to meet
    The other two are going to cost between £75 and £100
    (All are part prices only, excluding labour)
    I've still not managed to locate the EGR valve on the Y30DT engine, even though I know what it looks like!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Where did you find an Isuzu EGR that cheap?
    The EGR is located on the left side of the engine under the ECU.
    Full Member Big Sig's Avatar
    Quote Originally Posted by Celes View Post
    The ECU is on the airbox! Remove the black engine cover, look on the left hand side, in the middle for a metal pipe. Its under there!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The one I meant is on the engine not the airbox. And I think I made mysef clear as to where the said ECU is located.
    Yes you did but there is no ecu over my egr that I am aware! The Ecu is behind the EGR if my memory serves. maybe you should post a photo or state that the ecu you mean has Izuzu written on it as its not the most clearly visable one when there is a phappin great one staring you in the face over the air box. just trying to be a bit clearer for someone who just may not know. No need to take it so personal
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    There is some Isuzu stickers on it
    The ECU itself may not be over the EGR, but the plate it is on covers half of the EGR. I might be wrong...I've a headache lol
    Lol me too now
    Full Member
    Bristol
    Hi what code reader are you using to get these codes.
  1. Replies: 0
    Last Post: 26th August 2012, 03:15
  2. fault codes eml
    By richy1974 in forum Engine & Drivetrain
    Last Post: 21st July 2012, 13:23
  3. 1.9 cdti power loss and fault codes
    By Biker in a suit in forum Diesel Engine related
    Last Post: 8th April 2011, 10:42
  4. Just Read Fault Codes Help! 3.0 CDTi
    By m300raj in forum Engine & Drivetrain
    Last Post: 6th December 2009, 18:55
  5. Fault codes on 1.9 120 cdti
    By Keith Jones in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:52
