Results 1 to 10 of 11
Thread: Wing Mirror - Fault! any ideas?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Wing Mirror - Fault! any ideas?
    Hi All
    Just noticed that when selecting the button for the left wing mirror it works fine!.... (up/down/left/right)
    but when I select the right button, and try to adjust the right mirror, it moves both the left and right at the same time!
    Is this a common fault? anyone else had this? simple fix?
    thanks guys!!!!
    [Ex]Admin Duncan's Avatar
    Not a fault, it's how it's meant to do it. A good number of threads on it on here.
    Basically you set your mirrors by having the switch on the right and adjust the right mirror (ignore what the left one is doing), then press the left switch and get your left mirror sorted. Now both are adjusted. Press the right switch and the idea is that if someone else drives the car then they just push the left/right button and both mirrors move inwards/outwards at the same time by the same amount therefore adjusting the mirrors in one go.
    Simples.
    11 Post(s)
    Mentioned in the handbook. But then who bothers to RTFM
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Simples.
    Thanks...
    Then i must have had a fault before.. as it did do it last week!...lol
    cheers!
    Have you changed your door modules? Fitted folding mirrors etc? On pre-face the normal one button/one mirror is what is normal, on facelift it's as you have described - but if a module etc. has been changed on a pre-face it will then usually change to the different way.
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    Our's does what the OP says too, never noticed for weeks until I parked the opposite way one day and moved the drivers mirror instead of passenger!
    Regular Member Craig1985's Avatar
    harwich essex
    funny you say that. I've had my car 2 n half years and never noticed it. Untill the other day when it done it? Strange.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hi Duncan..
    No, nothing changed at all, but as the wife uses the car to go shopping in i often have to chnage the mirrors, seat, etc... and for the last year i havnt noticed.
    Its probably my lack of observation, i will admit, that last week i did change both mirrors to my preferred position and didnt notice then, hence my comment.
    Learn something new every day!... lol
    11 Post(s)
    Quote Originally Posted by dv8 View Post
    You probably changed the drivers side one first, not noticing the passenger side one moving as well. Then set up the passenger one afterwards.
    This time I imagine you did it the other way around, ie passenger side first, then drivers side.
    slough
    hi guys to quosh this once and for all if your vec c was pre 03 plate it had a switch on the drivers side that looks the same but is in fact diiferent in side pre 03 swithes move each mirror seperatley after 03 they move both this happend for gm beefits not customers
  1. Passenger wing mirror fault
    By portreathbeach in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2012, 23:03
  2. wing mirror
    By churchill254 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2010, 12:59
  3. '03 Vectra window/wing mirror fault
    By bluesfromagun in forum Bodywork & Interior
    Last Post: 20th May 2009, 20:40
  4. wing mirror
    By garyb in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2008, 13:45
  5. Wing Mirror
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2007, 23:36
vauxhall astra electric wing mirror fault
