Results 1 to 10 of 19
Thread: engine noise
    Sep 2009
    campbeltown argyll
    Default engine noise
    i have had my vectra now for just over a week but since i got it i noticed the engine makes a "ticking" noise when sitting idleing. Is it maybe just the noise of the car or should i maybe give it a service and see if that help!!!
    it sounds more like a diesel then a petrol!!!
    cheers colly
    Regular Member Fruit'n'nut's Avatar
    Thumbs up
    Quote Originally Posted by colly View Post
    i have had my vectra now for just over a week but since i got it i noticed the engine makes a "ticking" noise when sitting idling (corrected spelling ) is it maybe just the noise of the car or should i maybe give it a service and see if that help!!!
    cheers colly
    Is it only audible when the car is idling? In gear or out of gear? Does it make a difference if the engine is hot or cold? Can you tell which area of the engine it's coming from? Which engine is it?
    I'm no expert but some of the others on here may be able to help you, though they might need a bit more info to go on.
    Sep 2009
    campbeltown argyll
    its a 1.8 petrol, it is more noisey when cold but you can still hear it when hot!!!
    i couldn"t pin point a place in engine tbh
    Mileage : 000
    When does this noise occure. I mean is, it only when the engine is cold ?.
    Edit. Just seen your reply. It sounds like one of the tappets is "sarved of oil". I take it the noise gets less prominent when the engine is warm. This is because the "tappet" is now full of oil.
    Normaly the noisy tappet is the furthest one from the oil pump.
    Sep 2009
    campbeltown argyll
    ed.... do ye think it would benifit from oild change and just a general service!!!???
    Mileage : 000
    I don,t think it will do any harm.
    How long has the oil been in.
    I take it you put the correct oil in when serviced.
    The mileage of you car will be a lot to do with it. My wifes Vectra 1.8 make a lot more of "this tappet noise" than it used to do. Admitily I did put Mobil 1 in for it,s service. (that is a very thin oil 0w40). I might try a thicker oil next time though.
    Sep 2009
    campbeltown argyll
    its at 85k at the moment when i got the car guy had said it was srviced i think under 10 k ago!!!
    what oil would ye recomend!!!
    Mileage : 000
    I have got some 10w30 ( fully synthetic)to try in Larisa,s motor. I don,t know if it is the best. But I am going to give it a try.
    Regular Member vectramad's Avatar
    Jan 2008
    portsmouth
    Talking
    mine does this when idle,1.8vvt had it since new now a year old still makes that sound...even i thought i had a diesel at first.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    isnt it the fuel injectors tapping??
  1. 2.8 engine noise help
    By Mogsy007 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 22:34
  2. Engine noise
    By LANCE1 in forum Engine & Drivetrain
    Last Post: 16th December 2012, 19:59
  3. 2.2 engine noise
    By 57alan0 in forum Engine & Drivetrain
    Last Post: 17th April 2011, 22:21
  4. Engine noise
    By adds83 in forum Introduce yourself.
    Last Post: 5th March 2011, 12:57
  5. Engine noise
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 13:09
vauxhall 2.8 v6 turbo engine tikck
vectra c 1.8 ticking noise when engine running
vectra c engine to noise
vectra 1.8 tapping noise at idle
vauxhall vectra c 1.8 ticking noise
vectra engine noise
