Thread: Z22yh EGR valve
    holland
    Default Z22yh EGR valve
    Good morning guys,
    i was looking for the egr valve on the z22yh engine, some threads said it was located on the passenger side of the engine. I think i found it, it has part number 24404025, 4 strangely shaped studs and one connector on top of it. Is this the egr valve?
    What kind of tools do i need to get it off?
    Could anyone give me some info?
    thanks
    greeting from holland
    mart
    holland
    guys,
    i had losen up the bolts, there was a liquid dripping out of the egr valve housing, is this coolant liqiud??
    because i can't see any fittings of the coolant circuit, does this mean it's internally connected to the engines coolant liquid circuit?
    That means i have to drain some coolant before removing the egr valve.
    is this the right conclusion?
    thx already
    greetz
    mart
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yes mate the EGR is cooled from the block so you need to drain the coolant slightly. There is a drain plug on the bottom of the radiator.
    holland
    thanks mate,
    i'll try it tomorrow
    greetz
    mart
  1. Brake servo Valve (one way valve)
  2. Fault p0400 (57) (EGR Valve Voltage Low) on Z22YH
    By VeCeZ22YH in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2012, 20:25
  3. z22yh oil pressure valve spring
    By charlicarrie in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 09:35
  4. Egr valve, swirl valve problems etc..
z22yh egr valve location
z22yh egr valve problems
z22yh egr
vanne egr z22yh
z22yh egr valve
