Thread: STARTER Motor Advice
    Nov 2007
    Stourbridge
    Default STARTER Motor Advice
    Wondering if someone can point me in the right direction where is the starter motor situated on the vectra 1.9cdti 's? i think some wires come off due to the engine under cover comming of on the motor way thanks to kwick fit employees! Cant start the car jump starts fine someone show me the way. hopefully by the time i get up in the morning ill have a better understanding.
    lol
    Nov 2007
    Stourbridge
    Just had it checked and been told its the starter motor can they just pack up in a split secound id allways thought they go off slowly
    Jul 2009
    sussex
    what are the symptoms?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    when you say jump starts fine ..do you mean it will push start fine .this could be the starter motor faulty ....if it will jump start useing another battery it sounds like your battery might be flat or your altonator isnt chargeing
    Nov 2007
    Stourbridge
    Quote Originally Posted by benny View Post
    when you say jump starts fine ..do you mean it will push start fine .this could be the starter motor faulty ....if it will jump start useing another battery it sounds like your battery might be flat or your altenator isnt chargeing
    sorry for the confusion nothing happens when i turn the key no noise no glitch nothing not even the tick i had the wires checked out theres power going to the connections on the starter had the jump leads put on with another diesel car still the same but when i roll it and jump it in gear starts fine no warning signs nothing may be the starter solenoid is faulty but cars just come to its 2nd birthday still underwarranty but being a cabbi its no good rolling the car evertime i get a job! lol
    Feb 2006
    dudley
    are especialy as im out in dudley tonight for a drink ill try and avoid any vec'c taxis i see for the ride home lol ....
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Definately a starter motor fault. Sounds like the solenoids gone however I don't know what the fuse/relay situation is with the Vectra. I'd check them first Can't imagine the connections on the starter have come loose..
    Nov 2007
    Stourbridge
    no connections are tight as a ducks arse! must be solenoid
    Nov 2007
    Stourbridge
    Its been Booked in at the dealer let them sort it out should be under warranty cars just come to its 2nd birthday
  1. Starter Motor
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2014, 13:01
  2. Starter motor
    By lencuff in forum Y & Z30DT Specific
    Last Post: 9th January 2013, 21:09
  3. starter motor
    By yorkshireborn in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2012, 11:06
  4. Starter Motor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 25th August 2012, 13:10
  5. Starter Motor
    Last Post: 14th May 2012, 18:57
