Thread: 2.2dti engine problems and limp mode
    Norwich
    Trim : SXi
    Engine : 2.2
    Default 2.2dti engine problems and limp mode
    Just to set the picture I got my car serviced last weekend by VX.
    Whilst driving to Croyde (800mile round trip) the service light came on with the big spanner and the car went into limp mode. I pulled over and turned the engine on/off and off we went again.
    Then it did it again and seemed to be everytime I tried to accelerate in 5th then it happened in 4th and then 3rd
    On the way home today must have happened 20 times and I ended up just switching the engine as I was driving and then flicking it back on and problem resolved.
    Anyone have any ideas what it could be or whether VX tampered with something as its never happened before the service
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    hmmm, have you checked all plugs are plugged in?? sounds like the split boost pipe problem but i have very limeted knowledge and they are much better people on here.
    Mine did a similar thing when I put a filter in, so it could also be MAF sensor.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Check boost hoses and the little rubber vacumm pipes as these have a habit of splitting
    Norwich
    Trim : SXi
    Engine : 2.2
    In any other VX I,ve owned the engine light comes on when the MAF sensor goes but I,ll check for split pipes - cheers!
    Regular Member garvey's Avatar
    Co Durham
    welcome to the world of the 2.2dti
    Norwich
    Trim : SXi
    Engine : 2.2
    Quote Originally Posted by garvey View Post
    Beginning to feel like it
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Check also the throttle body. Same problem on mine 2.2 DTI, solved changing the throttle body.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As said before check your vacuum hoses are not split or more than likely that they have been put back securely and in the right place ( the dealer i took mine to got it wrong and reversed the hoses ) which gave me the same problem as you are suffering.
    and still loving it
    Regular Member david.aka.judas's Avatar
    Suffolk
    clean the EGR valve, check hoses and pipes.
    Norwich
    Trim : SXi
    Engine : 2.2
    Checked all hoses all ok have now done a further 300+ miles and no problems at all......I,m confused lol
  1. Lumpy engine then limp mode
    By themarbleman in forum Y & Z30DT Specific
    Last Post: 1st August 2012, 20:17
  2. (2.2DTI SRI)‘LIMP HOME MODE’ icon. Turbo stops working!
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 15:03
  3. Help! Limp home mode after DPF problems
    By Awkward kid in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:30
  4. 2.2DTI LIMP MODE + SPANNER + Engine Managment Light
    By s0501291 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:42
  5. Intermittent limp mode on 2.2DTi
    By Celes in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 23:12
2.2 dti intermittent limp mode
