Results 1 to 10 of 29
Thread: injector problems
    jilava
    Default injector problems
    I did a static DPF regeneration today and thought I'd look at the engine and I saw this:
    Attachment 25390
    the #4 injector is soked wet. What is causing this and what can I do to fix it?
    thanks
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    If its coming from the top of the injector then it'll most probably be the plastic leak off pipe. Clean around the area and start the engine and see if its coming from that. If its that you'll need a new 'leak off pipe' assembly which is about £30 or so i think. Easy enough to change.
    If it was the injector itself i would expect not to see diesel all over the top of the injector.
    jilava
    A diagnostic tool gave me these readings of the fuel injection:
    Attachment 25392
    what do these mean???
    also I've seen tiny drops of fuel that seem to be coming out of the electric plug and splashing towards the injector and there are also tiny amounts that splash from the top of the injector, where the hose is connected with a clip.
    How bad is this? do I need to change the whole injector? help please!!!
    jilava
    thanks for the reply plasma, it's from the top and from the electric plug towards the injector. I don't understand how can it come from the electric plug?! what's the role of the plastic leak off pipe? do I need to get only the piece in between the 3rd and 4th injector or should I replace it for all the injectors?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    how did you do a static regen ?? it looks like injector 4 is leaking i would say via the plug or pipe ....
    jilava
    with an op-com. I will clean it tomorrow and see exactly where it's leaking
    Feb 2006
    dudley
    does op com give you the warnings tech 2 does ....? ....... did you check the oil life remaining ? or dont opcom give ya this info ? ...........
    jilava
    i think it does, didn't check for the oil life remaining but I can get the next service interval in km by pressing and holding the button on the spedometer... it sais something like 18000 Km. why do you ask?
    Feb 2006
    dudley
    it got nowt todo with when it is next due a service it is a reading in the ecu of how good the oil is you cant do 2 regens on top of one another you have todo about 50 miles between ....if the oil life is low ie it has been contaminated with deisel from doing or atempting a regen it has been known to wreck a few engines they can over heat and die .... i wouldnt do a another regen soon and if ya do might be a good idea to change the oil if you aint done it for a while .......
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    benny, how does the oil get contaminated with diesel via a regen?
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
