Results 1 to 3 of 3
Thread: Enginge problems- can you help with diagnosis?
    Sep 2009
    oxford
    Default Enginge problems- can you help with diagnosis?
    Hello all
    I bought a Signum estate 1.9 cdti yesterday, '54 plate and 66k on the clock. Lovely car and I was initially very pleased with how it was performing on the motorway. However I have since realised that when accelerating in 2nd/3rd from a little below 2000 revs to a bit above, the car judders, as though it is on the power, then coughing off, then a little more power, than backing off again. Any idea what this could be?
    The car comes up as a 150 on the insurance database, although I thought it was a 120. There is no red on the engine label on the back of the car!
    It is an enginge with a cam chain rather than a cam belt. I can find the engine number if this is any help.
    Thanks in advance
    George
    Sep 2009
    oxford
    ps- There was a slight engine whine when I took the car for a test drive before buying it, so the dealer replaced an alternator brush (whatever that is) before I picked it up, which fixed the noise. Could this be related?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Could be the usual EGR fault, this effects power around the 2k rev mark, can be cleaned for free and an hour of your time, or replaced for about £90.
    Where is your oil filler cap on your engine, if its on the right hand side (as you look at it) its a 150, the left a 120.
  1. diagnosis time
    By roverjay in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 12:05
  2. Engine Diagnosis
    By stevej in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2009, 10:46
  3. Fault Diagnosis
    By jamesworts in forum Vectra C / Signum Troubleshooting
    Last Post: 6th August 2009, 21:36
  4. Diagnosis needed
    By Finty in forum Suspension, Wheels & Brakes
    Last Post: 5th April 2009, 19:33
  5. VX mis-diagnosis!!!!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 8th February 2007, 22:39
