Results 1 to 10 of 15
Thread: PC99-X45 help please
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default PC99-X45 help please
    I've just installed a Pioneer HU into my 54 plate vectra, and it is up and running fine.
    Last night i got the PC99-X45 harness adaptor and the PC99-PIO patch lead.
    I went to connect these up and......nothing...no power or anything.
    There are two red and yellow wires on the X45 that are unconnected.
    What do i connect these up to?
    I connected the red upto the thick red on the back of the cars ISO block - but this just gave me a permanent live (the steering wheel controls worked tho)
    any ideas?
    cheers
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Opel/vauxhall have reversed ignition and permanent live..
    so you have to put them round the otherway.
    Apr 2008
    North East
    I've got the unit working without the harness adaptor, but it's when i add it that i cant get it on.
    Regular Member braby's Avatar
    Watford
    I had to swap the wires around on the patch leads as well as the head unit to get mine to work.
    Regular Member paul.sessions's Avatar
    leighton buzzard
    plug them into each other and the stereo will work i had this problem a while ago with the same lead i sent it back in the end bacause i couldnt get the steering controls to work,, you might have to swap the red yellow on the stereo harness too
    Apr 2008
    North East
    Quote Originally Posted by paul.sessions View Post
    just tried this.....stays on permanently
    Sep 2009
    north lanarkshire
    Default hi monkezz
    i was told it the pc99-x06 for 05 vectras and pc99-x45 is for o2 to 04.if this helps any.cheers
    leighton buzzard
    ok plug them into each other then try different combination with red and yellow on the pioneer harness lead im sure i got one way to work
    Sep 2009
    north lanarkshire
    Default hi monkeez
    hi monkezz.
    what you need to do is on the pc99-x45 lead the end that joins to car loom have a look for white wire and orange wire.there is a space between them you need to fit a wire with spade connection into it and join it to the red wire with the bullet connection this is for the switched live.
    then have a look at the back of your 3100 unit for the remote wire and join that to the blue wire remote with bullet connection keep the red to red and yellow to yellow on back of your head unit no need to reverse it .then reset unit and all is working with full s/controls
    Regular Member jacko39's Avatar
    Sep 2009
    Derbyshire
    Quote Originally Posted by monkeez View Post
    any ideas?
    cheers
    Did you get the HU working with these leads in the end? I'm just about to purchase these leads for my new Pioneer Avic HD3.
  1. pc99-x45 stalk adaptor
    By jamie226 in forum Electrical & ICE (including SatNav)
    Last Post: 14th October 2009, 14:33
  2. Autoleads PC99-ALP
    By scott_150cdtisri in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2007, 15:20
autoleads pc99-x45
