Thread: DTI 2.2 Rear suspension
    Jul 2009
    Cheshire
    Default DTI 2.2 Rear suspension
    I'm new to this - but not VauxhalLs.
    Recently aquired a 2.2dti, the old Omega finally giving up th ghost ( which miss).
    On all normal road surfaces including speed humps the rear suspension seems fine. But if you hit a sharp pothole there is an obvious knock. The acr has had new rear shocks in the past and has onmly done 50k so i would assume these are ok.Anyone any ideas? ( the Omega did 160k without any rear suspenion problems - don't build cars th same ... sigh)
    Regular Member P-Mutton2.2's Avatar
    Aug 2009
    Frinton on sea
    Hi desmo,
    Lots of threads on this topic, I have a 2.2DTI also, not sure if model makes any odds my elite had incredibly sloppy rear shocks, also check rear bushes (rose bushings?) and the arm bushes, if there is excessive play in the wheels these may be to blame.
    I got help on this recently here and all sorted now.
    VX springs are notoriously poor and may have cracked or broken.
    If the car is playing fast and loose (that kinda fishtailing feeling) at the back handling wise the shocks may have gone or just not be very good.
    Think thats about it hope that helps, hope its ok, sure i'll be corrected if not
    Jul 2009
    Cheshire
    Many thanks, i'll investigate further at the weekend.
    EVERYWHERE
    Rear lower suspension arm bushes are notorious for the cause of the knocking noises described.Plenty of threads about it in the relevant section.
    Regular Member Middo's Avatar
    Swindon
    I thought it was the upper arm that caused the knocking too
    http://www.eurocarparts.com/ecp/c/Va...rms-and-Joints
    luckily vx bits are cheap, I am going to replace mine tomorrow as I too have a sloppy rear end
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Middo View Post
    The knocking SHOULD be the upper control arm, I've just bought two off ebay for £25 each, Vx want £75 each!! Although, after buying I noticed the same items listed as "trailing arms" which are priced on there for about £25 for a pair
    I'll be changing mine next weekend, and following this How2 from here;
    http://www.vectra-c.com/forum/showthread.php?t=46991
    Also I'm gonna change my anti roll bar bushes whist I'm "down there", £3.78 each from Vauxhall;
    http://www.vectra-c.com/forum/showthread.php?t=70861
    Hopefully solve my "loose rear end" - more tea vicar??
    EVERYWHERE
    My bad.
    Yes,it's the upper arms...but check the lower ones as well.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    the antiroll bar bushes can rattle to i found this out after replacing the rest of them , a bit of bike tube solved the rattle
  1. rear suspension
    By leedavis1971 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 21:33
  2. Rear arm suspension
    By Sambor in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2010, 10:37
  3. rear Suspension
    By Tom Tom in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 00:11
  4. rear suspension
    By DennisTheMenace in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2008, 18:33
  5. Rear suspension
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:05
