Thread: Manually unlock boot
    Default Manually unlock boot
    Hi Guys
    I have a 54 vectra 1.9cdti Elite with an alternator problem and the battery is now flat.
    The driver door can be unlocked with the key but is there any way to unlock the boot?
    Thanks in advance
    Daz
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If key wont unlock it and its a hatchback i'm sure that you can could climb into boot and there's a small circle shaped part of plastic you can pop this off to reveal a square hole pop a screwdriver into it and turn it to unlock,sure some one will explain better than me
    Irmscher Insignia CDTI 130
    Thanks,
    There is no external keyhole on the boot.
    I have just climbed into the boot and found the cover as you described (not opened yet as no screwdriver to hand and still officially working).
    The other thing I noticed is that I always thought that the veccy boot was quite big but its not that big for a 6'2" bloke!
    Thanks again
    Daz
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Why did VX ever take that external keyhole away. I've used mine a few times.... must be a money saving thing! Typical
    11 Post(s)
    Quote Originally Posted by DazMelling View Post
    The logical answer would be to recharge or put a fully charged battery on the car.
    Oct 2007
    Gloucester
    Ha! I'm 6'6" and have a non-operational boot motor. Needless to say, after a few less than graceful entry attempts, I have decided that the rear seats will do just fine for now.
    Hi
    Thanks for your posts, eventually "acquired" a charger and charged the battery.
    Daz
  1. Replies: 5
    Last Post: 2nd June 2012, 02:01
  2. Can I move EGR manually?
    By krisby in forum Engine & Drivetrain
    Last Post: 25th September 2011, 18:27
  3. Manually open throttle body???
    By john506 in forum Engine & Drivetrain
    Last Post: 22nd September 2011, 23:13
  4. Manually Operated window to Automatic.
    By 123rado in forum Electrical & ICE (including SatNav)
    Last Post: 17th June 2010, 21:30
  5. Boot unlock switch
    By jsr645 in forum Bodywork & Interior
    Last Post: 10th November 2009, 18:48
