Thread: What are these wires?
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default What are these wires?
    Probably covered before, but i have tried searching and cant find the answer.
    Behind my glove box to the right hand side (part of the stereo loom?) there are two connectore. One only with 2 wires one with about 6 ( I will try take pics in a bit). I think one might be to do with haveing a car kit, if so which and what is the other onw.
    Any help much aprecaited and if need i will post up pics in a bit.
    Stephen
    Nottinghamshire
    If you have a connector for a phone kit it is found here. It's a black 18-pin connector - 2 rows of 9 pins each - and has a grey locking clip around it that locks it onto the car kit connector that you plug into it. It's on quite a long cable - just about reaches across to the other side of the glovebox opening.
    Jul 2010
    Warrington / Liverpool
    I know this is an old thread but does anybody have a pin diagram for this plug as I have just found it and whoever owned the car before me has left some push on connectors in the butchered wiring (presumably from an old install they did themselves) and just curious as to what they all do...
    Also found some fairly heavy gauge cabling running front to back lol... Anybody into ICE installs ever owned my vec? **52 FKV
    Nottinghamshire
    Here are the pins on the VDA connector if that's what you mean. Sounds like you have the same problem I had - VDA connector butchered by previous owner to fit car kit instead of using proper adaptor cable.
    Some pictures would be useful if you need any further help so we can see exactly what you are referring to.
  1. Routing wires
    By JonnyB_UK in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 21:42
  2. 2.0 DTI MAP sensor wires
    By grabos in forum Engine & Drivetrain
    Last Post: 17th July 2011, 09:30
  3. best place to run wires?
    By mattster87 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2009, 20:14
  4. help with wires
    By simon5800 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2009, 16:01
  5. what are these two wires for?
    By JammyBStard in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2008, 19:25
