Thread: Noise from cat
    Regular Member tat2006vectra's Avatar
    plymouth
    Thumbs up Noise from cat
    Hi there I have a rattle coming from my cat converter and someone has told me that I need a new 1 or I could just knock it all out, pretty skint a the moment so was thinking cheapest option first but if I knock it out would it bring the engine light on ????? Thanks it's a 2.2 petrol if this helps
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    You may find that the rattly is the flex pipe splitting up. Best bet is to get underneath yourself and see whats going on.
    If its disintegrating, it may be a new CAT needed or get a flex piece and get someone to cut and shut it in.
    If its just rattling, get a large jubilee clamp around it. Someone did it on here and it sorted it, I will try to find the link for you.
    Blantyre
    Dont think that decatting it will bring the light on, seen a post here sometime ago, as your not removing the Lambda sensor, should be ok
    2.2 geniuses will be along shortly
    Birmingham
    Regular Member ballan22direct's Avatar
    isle of lewis
    i love this site. i was about to get the cat changed till i read this. problem sorted. hope thats not what was wrong with my old audi as that had 3 new cats in the 4 years i had it because of an annoying rattle.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    De catting a 2.2 will put the car into limp as there's an O2 sensor before and after the cat. Its only the CDTI's and the V6 petrol that can be decatted. The cat on the 2.2 is in the manifold before the downpipe not under the car. Its more than likely the wire braid around the flexie, its only a cover and as said can just be clamped back in place.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
